Painting An Engine Block
Posted 26 May 2019 - 07:46 PM
What Etch Primer should I paint the block with after it’s been machined (or should I paint it before hand).
For the Top Coat I guess an engine enamel, unless anyone wants to recommend anime thing else.
As far as colour, it will be a 1293, so it will either be red or I have seen a few nice looking black ish colours - what do you reckon?
Posted 26 May 2019 - 07:58 PM
Just use a piece of scotchbrite or 150 sand paper and you can then simply prep clean and paint the motor. I wouldn't media blast it for various reasons
Edited by cal844, 26 May 2019 - 08:00 PM.
Posted 26 May 2019 - 09:27 PM
I'm pretty sure I just wire brushed my block and painted directly with this stuff https://www.ebay.co....l-BMC-MOWOG-Gre, Goes o well, they sell other colours as well.
Posted 26 May 2019 - 09:42 PM
Warm the block with a hot air gun before you prime/paint it for a longer lasting finish.
Posted 27 May 2019 - 01:47 AM
engine enamel goes onto bare metal no need to prime
Posted 27 May 2019 - 05:41 AM
A spray can of high temperature engine paint is cheap enough. Remember to paint the inside of the block with red oxide primer.
Posted 27 May 2019 - 10:23 AM
Inside the block? Do you mean the area under the cylinders?A spray can of high temperature engine paint is cheap enough. Remember to paint the inside of the block with red oxide primer.
Posted 27 May 2019 - 06:30 PM
Why on earth would you paint the inside? silly idea!!!! Do not do that.
Posted 27 May 2019 - 07:10 PM
Are you thinking of this:
Although, I'm still not sure why he is doing this.
Posted 27 May 2019 - 08:31 PM
Yes, thats it. Pic of my engine.
Posted 28 May 2019 - 08:54 AM
Not sure red oxide is the right paint ... being more of a primer is it likely to still let the oil through .. the one above from frost's is
Edited by gazza82, 28 May 2019 - 08:54 AM.
Posted 28 May 2019 - 12:37 PM
I recommend POR engine enamel: https://www.carbuild...ne-paint-42268 really, really good stuff.
Posted 28 May 2019 - 03:35 PM
I have used the POR stuff which is great, unfortunately they didn't do it in the colour that I wanted so after advice from my father, got some 2K mixed. Brushed it on. It looks great!
