Grease Gun
27 replies to this topic
#16 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 18 March 2020 - 04:12 PM
Has anyone got any idea where I can get good quality grease to fill my grease gun?
Minispares
Thanks!
Doh!
I didn't think to check them.
#17 Spider
  • 14,849 posts
Posted 18 March 2020 - 06:15 PM
Has anyone got any idea where I can get good quality grease to fill my grease gun?  I just used the last of my Castrol MS3 molybdenum grease and it appears to be unobtainable in tins anymore.
While Molly Grease is a very good choice of grease to use in Ball Joints, it's not at all a good idea to use in in the Suspension Arms.
Molly Grease works very well, where parts slide over each other, but it shouldn't be user in Bearings that have rolling elements, like Suspension Arms. It usually doesn't allow the rolling elements to roll and so they slide causing flat spots on the shafts and needles (in the case of the Arms).
#18 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 18 March 2020 - 07:04 PM
Good to know, Moke Spider.
#19 RooBoonix
RooBoonix
  • 1,224 posts
Posted 19 March 2020 - 10:15 AM
Would a good quality EP lithium grease be a suitable option for all grease points on a mini?
#20 Spider
  • 14,849 posts
Posted 19 March 2020 - 10:26 AM
Off hand, I think an EP is what's recommended, but my own opinion is yes.
I've recently bitten the bullet and now using molly in the ball joints and EP in the suspension arms.
Lithium is a very good base and Clay too is OK, but it's not recommended to mix them.
#21 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 24 March 2020 - 07:41 PM
As far as the coupling goes, I found an Aussie one that is real good at releasing when you want it to. I broke a grease fitting on my Kubota tractor because the regular coupling would not release. It is very narrow so it gets in tight places almost as good as a regular coupling and when it captures, it seals very well. However, the outer casing can not contact anything around or the coupling will not latch on. Not cheap though. The brand of the coupling does not suit this type of lubrication application though.
Edited by xrocketengineer, 24 March 2020 - 07:45 PM.
#22 Spider
  • 14,849 posts
Posted 24 March 2020 - 08:44 PM
Ha - I was only looking at these on the counter of one of my parts suppliers last Friday. There's a few types and lengths and do appear 'the goods' but seriously over priced !
They did have a different branded one there as well, but equally as crazy priced too.
#23 Icey
Icey
  • 1,551 posts
Posted 24 March 2020 - 10:15 PM
The Swiss made Wanner guns seem to be a good reliable choice
I bought used Wanner and Rom Pom grease guns from eBay for ~£20. Much, much better than any of the modern (albeit it generally cheaper) ones. Have a look on eBay, lots on there.
#24 cooperd70
cooperd70
  • 727 posts
Posted 25 March 2020 - 06:59 AM
Icey,
I bought a Wanner from eBay. The section that holds the grease is grease-tub shaped (not a slim bodies one). It has a chain that attaches from within the gun and runs out through a slot in the lid (even tho the lid on the body is screw fitment). Have you seen one like this? It still has grease in it from when I bought it so don't need to get the lid off at present, but doesn't look obvious on how to get the thing undone. If anyone knows....
#25 MatthewsDad
MatthewsDad
  • 812 posts
Posted 25 March 2020 - 07:56 AM
Icey,
Pull the chain down to compress the internal spring and lock a chain link into the slot at the bottom of the cylinder, unscrew top off gun, pack cylinder with grease, screw top back on, release chain from slot. As the compressed spring is released it compacts the grease towards the top of the cylinder to create pressure. There are two threaded screw 'valves' at the top of the gun to allow air bubbles to escape.
#26 MatthewsDad
MatthewsDad
  • 812 posts
Posted 25 March 2020 - 07:58 AM
Having just re-read your question I don't think I've answered it as you're asking about a different design. Sorry about that.
#27 Icey
Icey
  • 1,551 posts
Posted 25 March 2020 - 10:31 AM
Icey,
Do you mean like this one?
eBay Link
Mine isn't like that (I have the slim version), but the design will be the same - the container the chain is dangling from will unscrew from the pump head. If it's been swung on by a maniac you might need to use a pipe wrench and a vice to get it moving.
#28 cooperd70
cooperd70
  • 727 posts
Posted 25 March 2020 - 09:27 PM
Yep!  That's the one Icey!  Both yours and MatthewsDad's comments have been noted and next time I'm in the shed (at least 12 weeks away as I'm stuck away from home during CV-19 outbreak) I'll take a look :D
