Best Answer rokemester , 05 July 2019 - 09:57 AM
Fantastic. Thank you I was hoping that was the case. Go to the full post
Posted 25 May 2019 - 12:06 AM
Posted 25 May 2019 - 12:22 AM
Posted 25 May 2019 - 02:05 AM
Posted 25 May 2019 - 05:55 AM
The black wire is to be connected to the earth wire which lurks under the dash area, the green one from the blower motor goes to the switch, and the other terminal on the switch must be fed from a green/brown live which comes from the ignition switch via the fuse box.
Get yourself a wiring diagram - plenty on this forum.
Posted 25 May 2019 - 06:50 AM
Originally the black wire is as above, the wire from the heater motor to heater switch is green/yellow and the power wire comes from the fused live to the wiper switch and is light green/orange.
It is in the Haynes manual in the wiring diagrams.
The opening closest to the clutch pedal is for the fresh air intake hose which connects to the air distribution box in the right hand wheel arch.
Posted 25 May 2019 - 04:57 PM
Edited by rokemester, 29 May 2019 - 05:41 PM.
Posted 29 May 2019 - 05:43 PM
Noted, and I have a Haynes manual. I just went through the wiring schematic and noted the major components.
Posted 29 May 2019 - 06:37 PM
Posted 29 May 2019 - 07:03 PM
Does this ductwork look familiar. Awfully cramped quarters to route ductwork to the front wheel well from the blower box.
That goes on the under the wing behind the wheel. the small holes goes to the dash vents in the corners of the dash, the one with the studs attaches to the inner wing and the big hole goes to the big hole in the front of the inner wing
Posted 30 May 2019 - 12:18 AM
Posted 05 July 2019 - 03:32 AM
Posted 05 July 2019 - 06:30 AM
The heater switch makes and breaks the circuit between the battery and the heater motor so it makes no difference which way round the wires are connected to it.
Posted 05 July 2019 - 09:57 AM Best Answer
#14
Posted 29 July 2019 - 04:04 PM
Edited by rokemester, 29 July 2019 - 04:22 PM.
Interior Light Upgrade To LedStarted by Husky31 , 05 Sep 2024 electrical |
Parking Lights Stay On One Side When Lights Are Switched OffStarted by boboleary777 , 04 Sep 2024 electrical |
Anybody Know What This Is?Started by BobbyMax , 02 Sep 2024 electrical |
Mk4 - Last Inline Glass Fuse Of Four No Power Running Through It?Started by postve , 26 Aug 2024 electrical, engine |
Mini Mk2 Temperature Sensor QueryStarted by DavidHopkins , 23 Aug 2024 electrical |
