From my limited googly knowledge, the oil filter is matched in pressure range / pressure release valve opening and volume as specced at OEM . On the standard 'small' spin on filters the bypass is usually specced at 8 PSID ,,, so when the pressure differential between outflow and inflow is 8PSI then the valve will release, on larger units that are often fitted in remote oil filter setups on the same mini, the bypass reference is 30 or similar PSID..... a bigger differential before the valve kicks in,,, this is (in my layperson's opinion) largely due to the flow requirements still being met due to the larger surface area of filtering media. So this agrees with unburnts statement above.
Apart from physical dimensions and thread sizes some of the more important filter info, such as do they work! is harder to find. It requires a phone call or two to the support line at the aftermarket manufacturer.. so you know what pressure the bypass kicks in at and what volume is to be pumped. The other less than easy information(sometimes) to get for comparing different products is their oil filter efficiency scale..... A nominal size say of 25 micron ( a human hair is 40-80 for reference) may sound good , but not as good if you find out it only is filtering out one out of every two of these size particles ( beta 2 measure) However if 98.7 percent of all 25 micron and above sized matter is filtered then you would be much happier ( Beta 75 measure). It would seem that the 98.7percentage figure is becoming the defacto norm, but ... watch out for sales pitch.
For Aussie readers our Ryco filters across the standard range is 25 or 30 micron if i recall correctly.... which is about par for the course. Dont know the syntech measure, because it wasn't recommended for race type environs.
For those thinking if 25 micron is good then 10 micron must be better, cleaner etc,,,,,, maybe,,,, but some of the oil additive packs have ingredients in them of around this size,,, so you might just be stripping the oil of some of its protective qualities.
So again it seems a fairly standard BMC OEM oil filter with a stock standard oil pump was a pretty good set up to start with. **** I have no idea if it is still a good setup for turbo, weird wonderful setups, so please do your own research****
back to The OPs question , the standard remote filter setup sold through minispares RFK9 and probably others fits a longer bigger filter cross check against Baldwin B178 or Mann w719/15
