It didn't work for me.. maybe I'm doing it wrong, but the rivnut just spun. I cheated and put it (10-32 unf) on a metric mandrel hand tight and use the normal tool. This worked and the thread was fine for the unc screw afterwards.
you hold the bolt and tighten the nut to pull the bolt up to compress the rivnut.
which side of the nut do the washers go?
Rivit Nut Tool
Junior Mini
, May 21 2019 02:58 PM
Best Answer nicklouse , 21 May 2019 - 02:59 PM
just use a well lubricated bolt some washers and a nut,
and a couple of spanners.
Go to the full post
16 replies to this topic
#16
Posted 23 May 2019 - 08:18 AM
#17
Posted 23 May 2019 - 08:21 AM
between nut and rivnut to stop the rivnut moving at the start. hence the well lubed comment. some times two washers help.
