When you do convert it is worth adding in relays too as the slightly higher wattage can take out your switch .. I'll be making my own when I get to do mine but I've read Wired-by-Wilson are good off the shelf additions
Thanks, would you recommend taking out the dim dip relay if adding in relays?
