Flywheel Removal Problem, Thread Info Sought Please
engine
Best Answer Dalek , 03 June 2019 - 11:46 AM
Thanks to all for advice on this thread :highfive:
Go to the full post
38 replies to this topic
#31 Cooperman
  • 23,225 posts
Posted 30 May 2019 - 09:08 PM
I once had one on an MPI which took over 2 weeks with my very big puller being tightened a bit more every day. Finally it just popped off.
#32 nicklouse
  • 18,477 posts
Posted 30 May 2019 - 09:09 PM
one point to note is a new puller does need some use for the ball to compress the center of the main bolt.
you did lube the main bolt.
#33 Cooperman
  • 23,225 posts
Posted 30 May 2019 - 09:25 PM
If it still won't shift, you could try hot/cold shocks. Heat up the mounting area with a butane torch or, an oxy-acetaline torch, then quench it with cold water, then freeze it with 'Shock & Unlock' then heat it up again. Keep on trying to tighten the puller as you do this.
It may take some time.
#34 DeadSquare
DeadSquare
  • 3,080 posts
Posted 31 May 2019 - 09:52 PM
Please forgive me for asking, but you have removed the big bolt in the end of the crank. ?
#35 nicklouse
  • 18,477 posts
Posted 31 May 2019 - 10:04 PM
you have to to use the guess works puller. but you could still leave the washer in place though.
#36 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 03 June 2019 - 08:58 AM
I borrowed a big snap on impact gun and it came off no bother !
Yay !
Craig
#37 DeadSquare
DeadSquare
  • 3,080 posts
Posted 03 June 2019 - 11:10 AM
Well done;  I knew it would come off in the end.
Can you still remember why you decided to remove it ?  Lol
#38 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 03 June 2019 - 11:46 AM
Yeah it's been a bit of an epic !
#39 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 03 June 2019 - 11:46 AM   Best Answer
