I'm about to fit my windscreen and my question is do i need to use a sealant around the rubber to body aperture and also between the glass and rubber?
Sealant For Windscreen?
Posted 12 May 2019 - 09:12 PM
Posted 12 May 2019 - 09:26 PM
I'm actually getting 2 screens fitted and sealed tomorrow, i can ask my fitter for product recommendations
Edited by cal844, 12 May 2019 - 09:27 PM.
Posted 12 May 2019 - 09:43 PM
Edited by Broomer, 12 May 2019 - 09:47 PM.
Posted 12 May 2019 - 10:03 PM
Posted 12 May 2019 - 10:04 PM
I'm sure my last screen was put in with "Arbormast" or something similar, recommend by a screen fitter. Didn't make any difference thought still leaked
My car leaked alot, from a missing 5mm wide section of corroded top dash rail /scuttle flange... ended that trip with wet feet and a radio with a mind of its own lol, sorted now though... We welded the corrosion and have sealed both sides of the front screen seal
Posted 13 May 2019 - 02:46 AM
Classic vehicles' windows are usually sealed with butyl rubber. The same stuff is used on interior door panels. It stays soft after it dries and is easily removed.
Posted 13 May 2019 - 11:13 AM
Posted 13 May 2019 - 12:21 PM
Is that before he fits it?
Posted 13 May 2019 - 02:16 PM
Posted 13 May 2019 - 02:32 PM
Never had a leak, never used a sealant.
Posted 13 May 2019 - 03:15 PM
You've been extremely lucky then. My '66 Mustang never leaked until I had a new windshield installed in it. The guy came back three times to fix leaks and it still leaked. I finally squirted extra in where it technically shouldn't be applied and fixed the leak myself.
Posted 13 May 2019 - 04:17 PM
Mini screens don't need sealant at all.
Posted 14 May 2019 - 12:58 PM
You haven't had a mini with a pin hole at the windscreen aperture
