Wiring New Starter With 'piggy-Backed' Solenoid
electrical
4 replies to this topic
#1 Hunter2
Hunter2
  • 211 posts
  • Local Club: Vancouver Mini Club
Posted 12 May 2019 - 08:19 PM
My built in Australia 1973 Mini originally had points distributor, remote solenoid and inertia starter....
The Solenoid wiring trigger wire White/Red trace coming straight from Ignition Switch to the WIDE BLADE on the Solenoid.
OZ Mini NOW has 123 Distributor (fully electronic), Pertronix coil...AND is getting a new Starter (for new flywheel) with 'piggy-backed' Solenoid.
Since the new solenoid is no longer just a relay, I understand that I need to wire in a Relay triggered by White/Red trace from ignition switch so as not to overload the switch etc.
So, I have wired in a Relay triggered by W/R with the relay receiving power (B) from the main terminal on the solenoid and sending power BR to the solenoid.
QUESTION - does the trigger wire (BR) from the new relay go to the Wide Blade on the new solenoid/starter unit?
ALSO, with the new distributor & coil, I presume that:
a)  the coil can receive a full 12 volts from the ignition keyed fuse box  CORRECT?
b)  there is no need to send full 12 v from solenoid to coil  CORRECT?
Thanks,
Hunter2
(from British Columbia on the West Coast of Canada
#2 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 12 May 2019 - 09:35 PM
White/ red wire goes to the large terminal on the pre engaged starter solenoid.
In my experience (of A+ engines, so alternator instead of dynamo) youll need a 12 volt supply to the coil, whether keyed or not (someone more experienced with your set up can confirm, or correct me)
Hope my ramblings make sense
Kind regards from a warm Scotland
Cal
#3 Hunter2
Hunter2
  • 211 posts
Posted 13 May 2019 - 04:09 AM
Thanks Call,
I also sent out this question to a few Mini mechanics on this side of the Atlantic and they agreed with my personal conclusions (answers Yes, Yes, Yes).
Unfortunate that NO info came with the starter/solenoid unit...and none readily available from the major suppliers in UK or major retailers of Mini parts in North America.  The starter/solenoid unit could be used in a variety of set ups.
The starter/solenoid unit could be used with fully electronic ignition or not.  This starter was sourced because I had also gone to a lightweight flywheel & back plate combination with different ring gear.
Rick
#4 nicklouse
  • 18,474 posts
Posted 13 May 2019 - 07:37 AM
just add this for info
http://www.theminifo...-to-pre-engaged
the later solenoid can be used just the same but I do like using the old one as a power distribution block.
#5 Hunter2
Hunter2
  • 211 posts
Posted 14 May 2019 - 12:48 AM
Thanks Nicklouse!
That is where I got to...eventually.
