Wiring New Starter With 'piggy-Backed' Solenoid
electrical
No replies to this topic
#1 Hunter2
Hunter2
  • 211 posts
  • Local Club: Vancouver Mini Club
Posted 12 May 2019 - 08:14 PM
THEN - 1973 OZ Mini originally had points dizzy, remote solenoid, inertia starter...
Remote Solenoid was triggered directly from ignition switch by W/R to wide blade.  Solenoid also fed 12 volts to coil on starting from narrow blade.
NOW - 123 Dizzy, Pertronix coil, starter/solenoid unit.
Understand that new solenoid requires more power than remote type, so Relay (triggered by WR) of power B from Solenoid main terminal & back to solenoid BR.  (have relay installed)
QUESTION - the triggered BR also goes to wide blade on new solenoid CORRECT?
ALSO -
a)  Since no points etc., I can wire coil directly from ignition keyed hot side of terminal on fuse block  CORRECT?
b)  No need to run any wire from the new solenoid to the coil  CORRECT?
Thanks!
