New Forged Rockers Contact Face Not Square To Valve Stems
13 replies to this topic
#1 mini-auto
mini-auto
  • Just Joined
  • 102 posts
Posted 10 May 2019 - 11:29 PM
Not keen on the contact angle between my new forged rockers and valve stems, presume this will result in premature wear to both rockers and valve stems.
I'm thinking the contact face on the rocker should be square to the end of the valve stem?
Should I return these forged rockers?
The cylinder head originally had late type rockers, I'm thinking I should get some new late type.
What would you advise?
#2 nicklouse
  • 19,058 posts
Posted 10 May 2019 - 11:58 PM
dont look good to me.
#3 Spider
  • 15,843 posts
Posted 11 May 2019 - 12:55 AM
Hmm,,,, not good at all.
#4 Chris.Williams
Chris.Williams
  • 679 posts
Posted 11 May 2019 - 02:09 AM
Where did you purchase those?
They look terrible.
#5 unburntfuelinthemorning
  • 2,003 posts
Posted 11 May 2019 - 06:20 AM
Where were they from?  There are good ones out there, these were from Minispares about a year ago:  HOKB6uh.jpg
#6 sledgehammer
sledgehammer
  • 3,131 posts
Posted 11 May 2019 - 07:11 AM
slightly off topic -
do them adjusters seem wound out a bit more than standard ?
are they new longer valves ?
(I can see the rocker faces are ground wrong)
just wondering
#7 GraemeC
GraemeC
  • 7,472 posts
Posted 11 May 2019 - 07:27 AM
I don't think there are any pushrods in
#8 Chris.Williams
Chris.Williams
  • 679 posts
Posted 11 May 2019 - 07:38 AM
Yes, these are the ones I have also.
No problem with them at all.
#9 Bobbins
Bobbins
  • 1,526 posts
Posted 11 May 2019 - 08:05 AM
Slightly OT ... what are the benefits of forged rockers compared to standard or roller rockers?
#10 unburntfuelinthemorning
  • 2,003 posts
Posted 11 May 2019 - 09:08 AM
Standard rockers are supposed to give a 1.25:1 multiplication ratio but often fall short.
Forged rockers give a 1.3:1 or 1.5:1 ratio (mine are 1.3:1) and are nice to look at.
Roller rockers reduce wear on the valve stem tip but cost a lot and don't always fit  under certain rocker covers.
#11 nicklouse
  • 19,058 posts
Posted 11 May 2019 - 09:33 AM
Slightly incorrect info there.
Standard pressed are 1.27:1 standard forged 1.22:1 standard sintered 1.21:1
#12 unburntfuelinthemorning
  • 2,003 posts
Posted 11 May 2019 - 02:43 PM
Fair enough.  I should have said that the forged rockers which Minispares supply (which are not original) claim to have 1.3:1 or 1.5:1 ratios.
#13 carbon
carbon
  • 2,590 posts
Posted 11 May 2019 - 08:23 PM
I had same issue with a set of S forged rockers from Minispares about 5 years back. Several of them were twisted similar to yours.
Used brute force to twist them back so lined up more squarely. Took quite a bit of effort, but seems to have worked.
#14 nicklouse
  • 19,058 posts
Posted 12 May 2019 - 01:12 AM
true. But you just said Forged.
