Does anyone have the answer on which way round this valve seat goes ?
I can see the argument for both but I'd really appreciate confirmation - I've marked them up.
I reckon it's purple which goes in first for what it's worth
Many thanks
Posted 06 May 2019 - 10:29 AM
Many thanks
Posted 06 May 2019 - 10:46 AM
Posted 06 May 2019 - 10:49 AM
Thanks, yes that's my thinking - the "green" side has the taper so the purple must be pressed into the engine
Posted 06 May 2019 - 11:23 AM
Posted 06 May 2019 - 11:28 AM
Posted 06 May 2019 - 11:42 AM
Refer the Photo in post #12 below
Edited by Moke Spider, 07 May 2019 - 07:30 AM.
Provide clarity as I can't see which end is what colour !
Posted 06 May 2019 - 12:00 PM
Looking at Vizard and Moke's post then it looks like green should be out then.....Why can't they just be the same !!! (I'm using a shuttle and not a ball by the way)
Thanks to you both - much appreciated
Edited by Kt1966, 06 May 2019 - 12:01 PM.
Posted 06 May 2019 - 07:38 PM
I actually suspect the photo in Vizzard's book has the seat back to front.
Posted 06 May 2019 - 07:56 PM
Although just looking at it now the tapered (green) bit of the seat doesn't fit at all well with the shuttle - you'd say that the sharper ( purple) end would be the better fit ( which is what Vizard is showing)....
Why can't both ends be the same....?!
Posted 06 May 2019 - 08:07 PM
Now I look at your pics again, I can't tell which colour is on which end.
As per the diagrams and photo here;-
http://www.theminifo...huttle-vs-ball/
Posted 06 May 2019 - 11:34 PM
The purple end has a step inside so the thing can be extracted from the block so green end out?
Posted 07 May 2019 - 01:19 AM
This is the end that faces out
Posted 07 May 2019 - 05:52 AM
Agree now. Unfortunately I just put my PRV and spring back in and don't really want to undo it because of the nice new copper washer
But when it was open I put my little pinky finger in the hole and it definitely felt like the shaped orifice in the photo above
Posted 07 May 2019 - 05:57 AM
May I suggest that someone puts a tap down one, inserts a bolt and pulls one out.
Posted 07 May 2019 - 09:48 PM
