Best Exhaust system for MPI mini Cooper
Posted 18 October 2006 - 08:11 PM
So what system do you think I should go for?
Posted 18 October 2006 - 08:14 PM
Its what I have, sounds excellent, although mine is a single box
Posted 18 October 2006 - 09:08 PM
Let her breath dude.....
Maniflow exhausts fit like a glove and work as they should.
Posted 18 October 2006 - 09:11 PM
Full Maniflow, single side exit, link pipe (no cat)
Mr 'Dude'... you can't just take off the cat, it's needed for MOT.
A Maniflow replacement with Cat will more than likely still breathe more than std replacment.
Edited by Retro_10s, 18 October 2006 - 09:12 PM.
Posted 18 October 2006 - 09:27 PM
Posted 18 October 2006 - 09:30 PM
Best thing I've seen is a play mini twin exit (both sides) with single back box. If you get a maniflow lcb and knuckle joint, even better.
Edited by nev_payne, 18 October 2006 - 09:33 PM.
Posted 18 October 2006 - 10:17 PM
Play mini cat link big bore pipe x 2, single box SIDE exit big bore scilencer and the correct INJECTION LCB. Needs some adjustment but is a good sound, not too loud
Forget all this fancey shmancey sh!t, its all show and no go.
Or you can do what Im doing come next MOT - Playmini bigbore LCB to back box link pipe and splice in a Jetex competition Cat. At £200 for the cat, its not something id expect a lot to do, but i want to retain the cat, but still be able to use it when i turbo the car on 16valves. The standard item is just so inadequate for that. LOL
Posted 18 October 2006 - 10:29 PM
Posted 19 October 2006 - 08:37 AM
Knuckle joint; pain in the arse!
Perhaps, but at least they dont wear out even half as fast as a mesh flex joint.
Posted 19 October 2006 - 09:05 AM
singe box if you want some noise or twin box if you want a quiet exhaust
Posted 19 October 2006 - 09:54 AM
Take it off and solid fix the exhaust like it used to be. Those rubber hangers are another waste of space. Thats the main reason the knuckle joint is there, because the exhaust moves so much on those rubber hangers.
Posted 19 October 2006 - 02:25 PM
Posted 20 October 2006 - 02:14 PM
Posted 20 October 2006 - 06:44 PM
Posted 20 October 2006 - 06:54 PM
Search on ebay
Shame realy because i had two and binned them because no one wanted them, just couldnt shift them.
