To Overbore A Little Or A Lot
27 replies to this topic
#1 unburntfuelinthemorning
  • 1,983 posts
Posted 01 May 2019 - 01:49 PM
My 998 block is standard size at 2.543".
I could probably get away with +0.020" but then I could go for a +0.120" overbore.
What would you do and why?
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 01 May 2019 - 02:04 PM
The smallest bore oversize you can get away with. Insurance should you have an issue with wear later on.
#3 DeadSquare
DeadSquare
  • 3,092 posts
Posted 01 May 2019 - 02:39 PM
If I overbored a 998 by ,120", I would move their center line apart and insert liners, so, if I wanted a bigger capacity, I would start with a bigger engine.
#4 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 01 May 2019 - 03:44 PM
You won’t get noticeably more power so whatever costs the least money to do!
#5 GraemeC
GraemeC
  • 7,438 posts
Posted 01 May 2019 - 04:01 PM
Go the full hog - 998 blocks aren't exactly hard to come by.
And I beg to differ that you won't notice the power difference, especially if the rest of the engine is built to suit.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 01 May 2019 - 04:42 PM
The full hog = 1098 crank as well!
And you you do notice the extra torque!
Ac
#7 unburntfuelinthemorning
  • 1,983 posts
Posted 01 May 2019 - 05:10 PM
Vizard always liked to max things out.  What are the chances of porosity problems though?
#8 DeadSquare
DeadSquare
  • 3,092 posts
Posted 01 May 2019 - 06:23 PM
@ AC,   What are the largest pistons available for a 1098 ?
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 01 May 2019 - 06:35 PM
68mm (+0.135") Producing 1219cc.
I am building a 1187cc (+0.100") version now.
Ac
#10 Spider
  • 14,849 posts
Posted 01 May 2019 - 06:37 PM
Biggest pistons off the shelf I'm aware of for a 998 & 1100 engines is 0.120" oversize.
Yeap, but also do something with the head too. It will need to breath.
#11 unburntfuelinthemorning
  • 1,983 posts
Posted 02 May 2019 - 10:58 AM
Do large overbores reduce block rigidity or is that not worth worrying about?
#12 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 02 May 2019 - 11:28 AM
A 998 or 1098 block will go to 68mm with no issues
With a 295 or 940 head and a decent cam, power and torque can double over standard
More cc is the best VFM [value for money] next is the cylinder head
The dyno sheet is a 68mm with a standard 940 head and 270 cam
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 02 May 2019 - 12:09 PM
I use sonic testing to check bore wall thickness. Not all blocks are equal!
And yes it goes without saying, finish the job with a sensible cam (peak power below 6krpm) and a nice flowed 295 based big valve head and you have a cracking road motor.
Ac
Edited by ACDodd, 02 May 2019 - 12:09 PM.
#14 G'Racy
G'Racy
  • 174 posts
Posted 02 May 2019 - 12:20 PM
Big valve head, what valve sizes would these be?
#15 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 02 May 2019 - 06:20 PM
I would aim for 1275 valve based 295 with 33.2mm inlets and machined down exhausts to 27mm.
Ac
