I've used a modified fork type ball joint splitter in desperation, luckily it worked without damaging the diff side cover.
Pot Joint Removal
#16
Posted 22 May 2019 - 02:03 PM
#17
Posted 22 May 2019 - 02:10 PM
I used to use a fork type ball joint splitter against the diff cover and never did any damage because the pot joints always came off easily. I've never had one this bad before.
#18
Posted 22 May 2019 - 02:27 PM
#19
Posted 22 May 2019 - 03:00 PM
I've been attacking it like this:
And it's achieved this:
It's only an old crowbar but it wasn't bent like that before.
As moke spider says keep going. It will let go eventually. You are endeavouring to "cut through" the jammed circlip.
Also as Rorf says try tackling it from underneath.
#20
Posted 22 May 2019 - 05:31 PM
I have one of these. It worked on the other side quite well when removing the engine but I bent it on this one.
#21
Posted 31 May 2019 - 02:22 PM
So I got my new special tool:
This looks more promising:
Half a dozen hits with a lump hammer later and:
Eureka! Came off easily. Saved from the angle grinder.
C-clip strangely intact:
Thanks for your help everyone.
#22
Posted 31 May 2019 - 04:11 PM
Newton's third law still true.
#23
Posted 31 May 2019 - 05:53 PM
At last - well done
#24
Posted 19 April 2020 - 06:45 PM
Glad you succeeded.
As is Murphy's
