Brake Shudder / Judder / Banging
brakes
Best Answer [email protected] , 23 June 2019 - 11:09 PM
Just to put a capstone on this post:
Shudder resolved with the installation of new EBC D182 rotors.
Once I pulled the calipers and the splash shields, I could see that the "highs and lows" that I thought was glazing was actually "lows and highs" due to rusting/pitting in the rotor surface.
Seems that only driving the Mini once a week and my notoriously "light touch" on the brakes, either anticipating the NYC street light changes and coasting, or just allowing the gearing and engine braking to slow me was allowing the surface rust that appears in between weekends to eat more deeply away at the disks.  I'm guessing that the hard slam on the brakes back on April 21st broke free some "wafering" and that then presented that rough "step transition" from normal high surface to abnormal low "valley of rust out" and created the banging shudder "out of the blue" even though the rusting had been long at work.
New discs and the Mini is a new car again!  Thanks to all who contributed thoughts and suggestions along the way.  :proud:
A quick word of warning for anyone fitting new rotors and the EBC pads with the pink "BRAKE-IN COATING":  Do NOT test out an "emergency braking to stop" scenario after initial installation!!
This stuff is SO aggressive that it was locking up my wheels to the point that it took a serious 1st gear and lots of throttle to get the wheels rolling again.  Yep, if I either stopped hard and left my foot down for a moment before lifting or if I pumped the pedal and then released when at a standstill, I was unable to roll the car afterward by hand (and yes, my caliper pistons had/have free travel and yes, we even opened the bleed nipple to ensure it wasn't back pressure in the hoses/pipes - it was not either of those things!)
That pink stuff also left a bunch of itself on the rotor if pressed hard, requiring about a half a block of feathering the brake pedal to scrape it off, thunk, thunk, thunking until it cleared.
It seems that the really aggressive pink coating just "bit into" the black "don't rust while sitting around" factory rotor coating (see pic of the rotor covering) and it just wouldn't let go!
I'm a few hundred miles into the new pads and rotors now and everything is fine, but I strongly recommend heeding EBC's caution in their installation materials: "...using brakes severely ONLY IN AN EMERGENCY..." for the first 200 miles of use!
Go to the full post
17 replies to this topic
#16 [email protected]
[email protected]
  • 127 posts
  • Local Club: Long Island Mini Enthusiasts
Posted 23 June 2019 - 11:09 PM   Best Answer
Attached File  EBCD182.jpg   36.81K   0 downloads
Attached File  EBC-Installation-doc.jpg   45.48K   1 downloads
#17 Rorf
Rorf
  • 866 posts
Posted 24 June 2019 - 05:56 AM
As a side line when did you last change the brake fluid. This should be done every 2 to 3 years especially in wet and humid parts of the country.
#18 [email protected]
[email protected]
  • 127 posts
Posted 24 June 2019 - 11:42 AM
Great sideline point for followers of this thread Rorf!  Definitely a recommended "regular" service in New England!
A local buddy of mine with a modern MINI (2002 supercharged) has the Dealership "drain and replace" every 24 months like clockwork (but he also tracks the car at over 110mph at places like Watkins Glen!)
WRT the last time I replaced all my brake fluid...it's been more, how should I describe it...?  "Piecemeal" perhaps?
In the 7 years I've owned my Mini, I have had the balancer valve up on the bulkhead fail (leaking out all in one go during a lunch in Brooklyn - thank goodness for a working dash warning light!), so the master cylinder has been completely flushed once, and I've had both rear wheel cylinders fail, one leaking like a sieve, one seizing up, so rear lines were also drained once each for the one man bleeding process (I always seem to go through more fluid just to be safe/certain).
But I will be swapping out my rubber hoses all around for braided Goodridge pieces this Summer (plus I'm replacing all the hard pipe from the splitter backward on the rear subframe while I'm at it) so I'll be cycling out ALL the brake fluid as part of that job as well.
Thanks to great contributing posts like Rorf's, I hope this thread has proven as "educational" for others as it has for me!
Also tagged with one or more of these keywords: brakes
