Mx5 Seats In A Mini
14 replies to this topic
#1 rolesyboy
rolesyboy
  • 34 posts
Posted 21 April 2019 - 06:42 AM
Folks, I am looking for inspiration. Has anybody made some nice looking brackets to fit MX5 MK1 seats in to a Mini. Anybody got any links or pictures of some.
I am avoiding the path of a load of agricultural box section or lumps of angle iron on the floor pan. Cheers. Mark
#2 PetePinnington
PetePinnington
    Formally known as PPinno
  • 367 posts
Posted 21 April 2019 - 06:54 AM
I used the original subframes from the mx5. Had some nuts and some extra metal welded onto the crossmember, and some extra strengthening on the floor and bolted it through. Really nice seats and sat nice and low. I'd have them now if I didn't have buckets
#3 rolesyboy
rolesyboy
  • 34 posts
Posted 21 April 2019 - 07:13 AM
Thanks Pete. Don’t suppose you have any photos you could share? Cheers
#4 Spider
  • 14,849 posts
Posted 21 April 2019 - 07:33 AM
Hey Mark !
Nice to see you over here mate.
I can't offer much in the way of fitting them in to a Mini, but should be fairly easy.
I do fit the MX5 NA Seats in our Mokes, using the original runners with some small modifications to them.
They are about the most comfortable seat I have anywhere, but I know that seats are somewhat 'individual' as well.
#5 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 21 April 2019 - 07:42 AM
I used the mx5 rails too. Some box section feet st the back and thick plate at the front to attach it to the standard pivot points. To lock it down it’s pretty unsophisticated but it works I have a large dead bolt.
I didn’t want it to be permanent so I can put the standard seats back easy
#6 Pairaminis
Pairaminis
  • 194 posts
Posted 21 April 2019 - 12:00 PM
Here's a link to pictures of a set of Miata frames I duplicated for the seats I put in my 84 Mini.  They're some additional pieces added to the Miata frames.
https://www.flickr.c...57627379237432/
Edited by Pairaminis, 21 April 2019 - 12:01 PM.
#7 DeadSquare
DeadSquare
  • 3,092 posts
Posted 21 April 2019 - 01:09 PM
I fitted a bench seat  ( I think it was from an A35 van ),  into my Mini pick-up.
Re positioning the handbrake took a bit of sorting.
I will leave to your imagination, changing a "magic wand" down into 2nd when my girlfriend was sat in the middle.
#8 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 21 April 2019 - 02:28 PM
Will need a mechanism to hold it down though when fitted for the MOT.
#9 Mat
Mat
  • 254 posts
Posted 21 April 2019 - 04:41 PM
Just weld some nuts to the cross member, then bolt the mx5 runners to them and directly through the floor at the back. Cants the seat back so you sit right at the back of it, it's really comfy!
#10 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 21 April 2019 - 06:11 PM
Would have been a folding rear A35 van/countryman seat then ....
#11 Manicmonkey85
Manicmonkey85
  • Just Joined
  • 20 posts
  • Local Club: Aberdeen Mini Owners Club
Posted 21 April 2019 - 06:37 PM
I have mk1 mx5 seats in my mini. They were there when I bought it but wouldn’t change them, super comfy and look cool. The speakers in the headrests are hooked up as well but not the best given my exhaust is that loud. If you need pictures of the frame I can take photos when I am next out. They use the mini hinges so they tilt.
#12 rolesyboy
rolesyboy
  • 34 posts
Posted 21 April 2019 - 09:20 PM
Thanks all. Manic monkey- yes please to any photos you can share. They look great in your car
#13 Manicmonkey85
Manicmonkey85
  • Just Joined
  • 20 posts
Posted 22 April 2019 - 11:45 AM
If you need any more photos or better photos let me know.
EDIT: Looks like some photos have appeared upside down. Don’t know why and not sure how to sort that. Apologies.
Edited by Manicmonkey85, 22 April 2019 - 11:47 AM.
#14 roblightbody
roblightbody
  • 441 posts
Posted 30 April 2019 - 07:03 AM
They look awesome. If someone made a bracket and sold them on eBay, they'd make some nice money.
Lots of mk2 mx5s are being scrapped (including ours soon...)
#15 PetePinnington
PetePinnington
  • 367 posts
Posted 04 May 2019 - 05:33 PM
You can see the where the nuts were welded onto the crossmember and the extra strengthening plates on the floor. I've not got any photos of the actual seat mounted unfortunately but I essentially just used the standard mx5 frames and bent the rear of them slightly to sit on the floor properly.
