'81 Pickup
pickup
416 replies to this topic
#406 KTS
KTS
  • 2,420 posts
Posted 22 June 2024 - 09:12 PM
Yep, feels much livelier; a little less on the bottom end, but quite happy in 4th from 2000rpm. Really picks up from 3k and keeps on going. I've not taken it much beyond 6k yet, but it does feel like there's more on tap.
All in all, pretty much what I was after. My compliments to AC
#407 KTS
KTS
  • 2,420 posts
Posted 23 July 2024 - 06:38 PM
I've been out and about in the car over the last month shaking it down and seeing what falls off;  literally in one case as i lost the pin from the upper door hinge on one drive.  Obviously only discovered that one when i went to open the door and the thing was just flapping about.  Fortunately i'm in the habit of supporting the door when i open it so nothing more than a bit of chipped paint as a consequence...
one one drive i noticed the steering was getting a little vague, and it felt a little like the front wheels needed balancing, so got it up on axle stands and found some play in the steering axis from paint between the steering arms and the hubs, so that was all scraped off and reassembled
Also adjusted all the shock absorbers to their softest settings and have been gradually firming them up to find what works best
I'd noticed a little rust bubble over the rear screen a while back and seeing as i had to sort out the paint chips around the door i decided to have a look at that at the same time
..knocked off the scab and scraped the surrounding paint back to bare metal
..a scrub with some deox gel to get rid of all the rust
..a bit of primer and a touch up, and good as new
Same with the door
..and then we get to the oil change;  same issue as before which is disappointing to say the least
Frankly, i can't be arsed to strip it all down again, so as long as i'm getting good oil pressure and it doesn't sound like a box of spanners in a tumble drier, i'll make the most of it and wait for the post-mortem to reveal what the problem was  ;D
#408 KTS
KTS
  • 2,420 posts
Posted 23 July 2024 - 08:26 PM
...something else I finally managed to identify was the cause of hydraulic fluid escaping from the clutch master cylinder - the cap wasn't sealing when tightened down, simply fixed using a O-ring inserted into the cap.  no leaks now...
#409 KTS
KTS
  • 2,420 posts
Posted 25 July 2024 - 01:43 PM
back on the rolling road for a setup session this morning
..and these are the results; running with the ACDodd RS+ cam
..and for comparison; the results from the session last year running a kent 266
#410 IronmanG
IronmanG
  • 1,227 posts
  • Local Club: Box hill. Lsmoc member
Posted 25 July 2024 - 04:14 PM
Pretty similar that.
Nice to have a back to back comparison even though someone will say the temperature was different......
#411 KTS
KTS
  • 2,420 posts
Posted 25 July 2024 - 05:08 PM
certainly interesting to compare them - the overlay of two charts highlights the differences a bit more, but I forgot to ask for a printout of that  >_<
the obvious difference is that the 266 gave more torque below 2800rpm, but after that the RS+ has a bit more, but what's particularly noticeable, especially when driving it (...which is really what counts..), is that although the torque kicks in a bit later, it builds much faster
#412 IronmanG
IronmanG
  • 1,227 posts
Posted 25 July 2024 - 05:27 PM
Looks like it's only revving to 5600 or so. Should be a fair bit more than that with the rs+?
#413 KTS
KTS
  • 2,420 posts
Posted 25 July 2024 - 06:02 PM
Yep - the thinking was that I may need to drop the compression ratio a little to allow more ignition advance
#414 IronmanG
IronmanG
  • 1,227 posts
Posted 25 July 2024 - 06:33 PM
AC recommends 10:1 I believe..
#415 timmy850
timmy850
  • 3,318 posts
  • Local Club: MITG
Posted 25 July 2024 - 09:16 PM
The power hadn’t tapered off yet, so there’s potentially a few more rpm and hp up further?
It’s a great result, hopefully it all works long enough to enjoy for a while!
#416 IronmanG
IronmanG
  • 1,227 posts
Posted 26 July 2024 - 07:21 PM
Ye looks good for 105 or so at 6250?
#417 KTS
KTS
  • 2,420 posts
Posted 26 July 2024 - 08:02 PM
possibly, on an engine dyno, but on the rolling road the cut off point seems to be where drag increases faster than power; from a tuning perspective i guess it's flogging a dead horse after that point
Also tagged with one or more of these keywords: pickup
