'81 Pickup
pickup
416 replies to this topic
#391 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 24 April 2024 - 09:05 PM
The cam journals look oil starved. What do the cam lobes look like for the pitted followers? What assembly lube was used?
#392 KTS
KTS
  • 2,420 posts
Posted 24 April 2024 - 09:33 PM
Torco MPZ cam lube was used at assembly
Lobes are unsurprising a bit chewed up, with number 3 looking like it's gone through the case hardening on the nose
I've been in conversation with Keith Calver and his view is that there's enough issues with the cam itself (cam journals not finished, suspicion from wear pattern there's insufficient taper on the lobes) for that to be the cause of the follower damage and the bearing material in the oil.
Next step is to choose a replacement cam and go again..
#393 KTS
KTS
  • 2,420 posts
Posted 30 May 2024 - 07:32 PM
back on it again now that the block and crank have come back from the machine shop with new cam bearings and a regrind
the block was looking decidedly shabby when it came back, so that needed stripping back and repainting; this time a closer match to the body colour
hopefully should get a bit more time on it at the weekend to clean up a few more parts before I start putting it back together again
#394 KTS
KTS
  • 2,420 posts
Posted 07 June 2024 - 08:42 PM
i did get a bit more done last weekend, but it didn't end well..
cleaned and refitted the crankshaft and checked the main bearing clearances with 2 out three showing less than 1.5thou, but the third one was showing 2thou, so I lapped the base of the cap to see if it would help.
it didn't.  what it did was lock the crank solid when i did the bolts up.  after much wailing and gnashing of teeth, with visions of having to get the block line bored to rectify my stupidity i reasoned that if i'd taken too much material away, as long as i'd done it evenly i might be able to shim the cap to get it back to usable.
after many hours and sacrificing several sets of feeler gauges i managed to get to a point where i could bolt down the cap with 4thou packing and get a reasonable bearing clearance, so ordered some 4thou shim stock and made up a set of shims.
it's not perfect, but it'll have to do.
3 thou crankshaft end float
stripped, inspected, cleaned and measured the oil pump - tolereances are all good, but i did have to clean up the underside of the rotor as it was scoring the base of the pump
refitted the timing gear back plate, camshaft and pulleys, checked cam end float and pulley alignment
put the chain on ready to start timing the cam in this evening, and then realised I hadn't fitted the oil gallery plugs so spent the evening taking the timing gear and back plate off and fitting the plugs instead.
getting there....
#395 evoderby
evoderby
  • 92 posts
Posted 08 June 2024 - 05:11 PM
STOP!
#396 evoderby
evoderby
  • 92 posts
Posted 08 June 2024 - 05:19 PM
Your car is way too nice to bodge the bearing cap clearance like that. I understand that you look forward to get things running rather than spend more time sorting problems….but this really isn’t the way forward.
Why does the crank lock up, what has changed since you last built up the short block? You mention a regrind….of the crank? How does it measure up? Do your bearings measure up ok? Something must be amiss.
#397 KTS
KTS
  • 2,420 posts
Posted 08 June 2024 - 07:20 PM
the crank locks up because i'm an idiot and took way too much off the bearing cap when trying to adjust the bearing clearance.
the block doesn't have enough life left in it to warrant getting it line bored, so rather than just scrapping it and starting again i figured i might as well take the opportunity to see if i could bush fix it.
#398 KTS
KTS
  • 2,420 posts
Posted 08 June 2024 - 08:28 PM
having fitted the oil gallery plugs it was time to do the cam timing - vernier timing gear certainly makes adjusting it a simple exercise.
a quick look at the big end bearing clearances..
...check the idler gear end float; 4thou will do
...sluice out the gearbox with paraffin
..and re-attach it to the block
#399 KTS
KTS
  • 2,420 posts
Posted 10 June 2024 - 08:44 PM
next job on the list was to pack all the drillings for the gear box fasteners in the block with grease to keep water and crap out
..give the gearbox and transfer case a good scrub, give it a coat of ACF50, refit the oil filter housing and transfer pipe, and fit the flywheel and crank pulley
ready to put back in the car.  cylinder head will get refitted once the engine is in and i've spun it over to get some oil through the system
#400 KTS
KTS
  • 2,420 posts
Posted 13 June 2024 - 08:41 PM
putting the engine back in turned out to be a bit of a faff as i couldn't get the pot joints back onto the output shafts, so decided to knock the pots of the driveshafts, fit them to the box and then drop the motor back in.
not having three hands, i needed to come up with a way of holding the driveshaft in place so i could knock the pot joint off with a long screwdriver, so came up with this, which works a treat
..which meant i could finally get the motor back in
#401 KTS
KTS
  • 2,420 posts
Posted 17 June 2024 - 10:22 AM
managed to make some progress over the weekend
alternative method for refilling with oil without the cylinder head on
..which meant i could turn the engine over and pump some oil through the system.  once that was done, it was time to refit the head and set the valve clearances using a dial gauge to check for max lift on the valves
then it was onto refitting the inlet and exhaust systems etc 'til i ran out of time
just need to refit the radiator, plumb in the cooling system and refill with clean water, pump through some fresh fuel, adjust the ignition map and then get it started and bed in the cam...
#402 KTS
KTS
  • 2,420 posts
Posted 19 June 2024 - 07:56 PM
it's alive !!
fired up first time and ran at 2500rpm for 20minutes to bed the cam in without any dramas.
may need to knock a couple of degrees off the timing as it was getting a bit warm towards the end.
i'll drain the coolant, retorque the head, check/adjust the valve clearances, put the wheels back on and get it back on the ground.  hopefully will be able to have it on the road at the weekend....
#403 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 20 June 2024 - 08:07 PM
Awesome Pat!
#404 KTS
KTS
  • 2,420 posts
Posted 22 June 2024 - 08:22 PM
..all back together again and back on it's wheels,
so took it out for a shakedown run on friday evening once the traffic had died down.  Happily, that was entirely uneventful
i'm liking the new camshaft  :D
#405 IronmanG
IronmanG
  • 1,228 posts
Posted 22 June 2024 - 08:34 PM
Sounds good looks good. Did it feel any different?
Also tagged with one or more of these keywords: pickup
