'81 Pickup
pickup
416 replies to this topic
#331 bpirie1000
bpirie1000
  • Area Managers
  • 2,373 posts
  • Local Club: Amoc
Posted 20 May 2023 - 08:37 PM
3 years and nine months after getting the car back, it's finally back on its wheels again !!
it would be nice if they weren't all pointing in different directions, but i guess you can't have everything  ;D
Wheely good progress..
Bet you are tired now..
No need to deflate you your progress is great.
#332 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 20 May 2023 - 10:48 PM
Those wheels look awesome in the gunmetal!
#333 KTS
KTS
  • 2,459 posts
Posted 21 May 2023 - 10:41 AM
i'm really pleased how they look on the car; gives it a more utility vehicle look than if i'd left them in silver, and in practical terms won't show up the dirt so much  ;D
#334 KTS
KTS
  • 2,459 posts
Posted 27 May 2023 - 07:02 PM
a few more jobs ticked off the list, and an extra one dealt with for good measure.
First up; fire extiguisher fitted. hopefully won't ever need to use it.
Dash liners fitted - apart from the drivers door pocket trim, and sun visors, that's the interior done
then managed to distract myself with another bracket creation job
it's only 3" higher than the original one, but makes a surprisingly big difference when working in the engine bay
and finished off by fitting the front number plate, grille, and after a good clean, the headlight surrounds.  just need to find the screws to fix them in place...
#335 wingnut
wingnut
  • 463 posts
Posted 27 May 2023 - 07:44 PM
Oh a norfolk reg.Wont be long before this is on the road surely?
#336 KTS
KTS
  • 2,459 posts
Posted 27 May 2023 - 08:33 PM
Hopefully not too long, but does depend on when I can get it booked in for suspension and engine setup...
#337 KTS
KTS
  • 2,459 posts
Posted 29 May 2023 - 08:36 PM
more bracketry today; modifying the steering wheel boss to work the indicator self-cancelling ring
the usual 2mm stainless plate after a few hours of cutting and filing
after some bending and a bit more filing, it's job done
#338 KTS
KTS
  • 2,459 posts
Posted 12 June 2023 - 08:47 PM
Got the car booked in with LynxAE to do the suspension setup and engine map;  the downside is that due to a combination of factors, that's not going to happen 'til the end of july.
in the meantime; and something i should really have done when the car came back from the body shop, i thought i'd better check the rear subframe geometry.
Diagonals came out within a couple of millimeters of each other, and with the aid of a plumbline, a marker stick to do the arcs off each corner, and a laser level i could plot the centre line of the rear subframe down the length of the car, and see how far off the centreline of the front subframe it was
3mm over 217cm, which according to my maths is naff all.
Assuming i haven't made a fundamental mistake in marking everything out and plotting the centreline, that's a good starting point, and a testament to Ben's skills when he replaced the floor.
I've also got round to putting an infill into the air duct to cover the hole i had to cut to clear the clutch cover casting.  Can't imagine it'll do much to improve airflow, but should at least keep the worst of the rain/bugs/grit from getting through
the other job that needs sorting is the tonneau.  the old one no longer fits as the fasteners are in slightly different positions, but i've managed to re-position most the eyelets so it fits reasonably well which means i can send it off to be used as a pattern for a replacement
#339 Colinmac1330
Colinmac1330
  • 261 posts
Posted 13 June 2023 - 09:55 AM
I may have missed this but what's the deal with the binnacle on the steering column? Looks good  :proud:
#340 KTS
KTS
  • 2,459 posts
Posted 13 June 2023 - 11:06 AM
thanks
started off as just a means of installing some additional gauges (vacuum, tacho & AFR) and ended up being a convenient housing for most of the control relays I added (horn select, AFR, lights on buzzer, fuel pump enable&prime and DRL)
https://www.theminif...ckup/?p=3690326
Still needs a cowling making to tidy it up, but from the drivers seat looks fine
Edited by KTS, 13 June 2023 - 11:20 AM.
#341 Colinmac1330
Colinmac1330
  • 261 posts
Posted 13 June 2023 - 12:32 PM
Ah yes, I did miss it then  :shy:  :gimme:
Looks really good, well done!
#342 KTS
KTS
  • 2,459 posts
Posted 25 June 2023 - 04:41 PM
After giving the car a clean for the first time I actually drove the car; forwards and backwards  :lol:
it was only a few yards out of the garage to take some photos in the sunshine, but that's the first time i've driven that car since 2009 !
#343 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 25 June 2023 - 06:56 PM
Well done Pat. Looks awesome. Been great watching it come together on here. Get an MOT. See you at a show
#344 KTS
KTS
  • 2,459 posts
Posted 25 June 2023 - 08:24 PM
Cheers !!
Assuming the engine survives the rolling road session I should be out and about in it from August; hopefully get a couple of months of decent weather to enjoy it
#345 IronmanG
IronmanG
  • 1,253 posts
Posted 25 June 2023 - 08:50 PM
It will be fine. What cam you running? I can't remember. Where you based?
Also tagged with one or more of these keywords: pickup
    Bing (2)
