'81 Pickup
pickup
416 replies to this topic
#271 ac427
ac427
  • 679 posts
Posted 15 August 2022 - 01:27 PM
Looks great.
Can I ask what tool you used to get the curved clutch/brake lines such a tight radius ?
..one of these
0BrmcOA.jpg?1
@nev100 Machine Mart sell them - https://www.machinem...ve-pipe-bender/
Edited by ac427, 15 August 2022 - 01:29 PM.
#272 KTS
KTS
  • 2,459 posts
Posted 15 August 2022 - 02:57 PM
Looks great.
..one of these
..to be clear, that is a different tool.  the one pictured is for 1/8", 3/16" and 1/4" pipe, the one you linked is for 6, 8 or 10mm pipe  (1/4", 5/16", 3/8" equivalent), so not ideal when working with 3/16" brake/clutch lines
#273 ac427
ac427
  • 679 posts
Posted 15 August 2022 - 03:51 PM
Looks great.
..one of these
Bugger, It looks a lot like the imperial one i own.
#274 nev100
nev100
  • Just Joined
  • 143 posts
Posted 15 August 2022 - 08:05 PM
Thanks for replies...
I've used the 'socket method'. Bending around socket in vice. Works a treat.
Thanks.
#275 KTS
KTS
  • 2,459 posts
Posted 20 August 2022 - 09:17 AM
Finally managed to find someone to weld up the exhaust sensor boss, which meant i could refit the exhaust.   one step closer to being able to (hopefully!) get the engine running....
much better now
compared to how it was before
#276 KTS
KTS
  • 2,459 posts
Posted 10 September 2022 - 07:13 PM
having got the exhaust sorted out i was ready to have a go at firing the engine up, so having spun it over to make sure it was making oil pressure, it was time to set the base offset timing on the ignition system
plugged it in, fired it up, and...nothing.  no spark and no lights indicating it was firing the coil pack, so sent it back for testing
in the meantime, i finally got round to installing a coolant drain by replacing the lower half of the radiator hose with the top half of another
Motorsport-Electronics tested NoDiz unit and were able to replicate the fault on the test bench so sent a replacement out, so i could finally try and start the motor
Happily, after a few tries, it sprung to life, and sprang a few leaks too !
However, as you will see from the picture below, it's pretty clear that something is not quite right with the setup
AFR gauge is showing 14-15, which suggests the mixture is in the right ballpark, which leaves timing as the probable cause;  whether it's a mistake on the base offset, or an issue with the process i followed when timing the cam in, they'll both need a bit more investigating...
#277 sonscar
sonscar
  • 3,039 posts
Posted 10 September 2022 - 09:22 PM
Always check spark timing before starting the engine is a good call.After setting my car on fire once it has become ingrained.Your engine bay looks very nice.Steve..
#278 fokko
fokko
  • 167 posts
  • Local Club: Mini Seven Club Nederland
Posted 12 September 2022 - 07:42 AM
Clever solution for coolant draining! I have been contemplating about this as well, but I might use your solution ;-).
#279 DUF2
DUF2
    Formally known as DUFfi
  • 457 posts
  • Local Club: Whickham & DMC
Posted 12 September 2022 - 10:28 AM
This is how I did my drain tap.
it is a plastic radiator, I bonded another piece of plastic to the bottom tank, the drilled and tapped it and fitted the drain tap.
Attached File  5DB1434E-945C-412B-AB01-D6E792318844.jpeg   91.3K   0 downloads
more photos can be seen here.
https://www.theminif...-4#entry3642025
Edited by DUF2, 12 September 2022 - 10:31 AM.
#280 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 12 September 2022 - 12:52 PM
I use a wet vac
#281 KTS
KTS
  • 2,459 posts
Posted 16 September 2022 - 08:44 PM
..checked the pulley timing mark - all good
..checked the cam timing - intake valve full lift at 103.5 degrees, so that's fine...
all of which means, i think, that it's got to be the timing that's out.  I've put together a few alternate map files using figures from other ignition systems and will try them out to see if i can find something that solves the very high exhaust temps i'm seeing
#282 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 16 September 2022 - 09:36 PM
Have you verified the idle timing with a timing light to make sure the offset is OK?
And have you got the MAP sensor hooked up to the manifold side of the throttle or the intake side of the throttle blade? The reading at idle should be around 20in/Hg
Edited by timmy850, 16 September 2022 - 09:40 PM.
#283 KTS
KTS
  • 2,459 posts
Posted 16 September 2022 - 10:03 PM
Base offset still needs to be re-checked. After the initial setup the timing light was showing 10 degrees advance during cranking which was correct for the default map.
MAP sensor is connected to manifold, but to rule that out as a factor, and as I'm not running under load anyway at this stage I've disabled the load mapping function.
Hopefully get a bit more time in the garage this weekend to have another crack at it.
Edited by KTS, 16 September 2022 - 10:04 PM.
#284 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 16 September 2022 - 10:11 PM
Did you do the free air calibration on the afr gauge ?
#285 KTS
KTS
  • 2,459 posts
Posted 16 September 2022 - 10:25 PM
No - according to the AEM 30-4110 documentation it's not required
Also tagged with one or more of these keywords: pickup
