'81 Pickup
pickup
416 replies to this topic
#256 carthorse
carthorse
  • 257 posts
Posted 23 July 2022 - 01:07 PM
I dream of being at this stage
#257 nev100
nev100
  • Just Joined
  • 143 posts
Posted 23 July 2022 - 03:36 PM
Looks great.
Can I ask what tool you used to get the curved clutch/brake lines such a tight radius ?
#258 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 24 July 2022 - 08:45 AM
Looks great.
I tend to clamp a socket in a vice and simply bend it around it by hand, no fancy tools needed as long as the radius isn't too tight and you take your time.
#259 nev100
nev100
  • Just Joined
  • 143 posts
Posted 24 July 2022 - 04:27 PM
Thanks for that.
I've got a pipe bending tool but can seem to get the tight radius.
I was thinking of other ways and thought bendjnd around a socket might work....
So that confirms it
Many thanks
Neil
#260 KTS
KTS
  • 2,421 posts
Posted 24 July 2022 - 04:29 PM
Looks great.
..one of these
0BrmcOA.jpg?1
#261 nev100
nev100
  • Just Joined
  • 143 posts
Posted 24 July 2022 - 08:38 PM
KTS
Yes, that's what I use....but find it's limited at getting a tight radius
#262 KTS
KTS
  • 2,421 posts
Posted 25 July 2022 - 08:05 PM
pickup continues to take a back seat at the moment, and looks set to continue that way for a little while unfortunately
i did however do something i've never needed to do before and give the K&N filter a clean and re-oil; strangely satisfying to see it change from grey/brown, to white and then back to red  :proud:
I was planning on trimming the doors myself and making up some custom door bins but decided that would just take too long, so ordered a set of door trim from Optimise;  went for the monte-carlo sytle with a dark grey stitch detail, and wasn't disappointed
..the only disappointing thing about fitting the door cards (..apart from no fitting instructions; fortunately NewtonCommercial website does have them), is that the wrestling the door cards in resulted in both door slipping on their fixings, so the cards will have to come out again, and the doors repositioned.
When i refit i'll make sure I brace the doors off the floor to stop them moving again
was also having issues clamping the fresh air hose to the bulkhead fitting i'd made up, as i couldn't get the clamps to fasten up enough, so used some self adhesive shrink wrap on the wire clamp to get it to grip the hose.  simple but effective solution
also fitted the radyot door mirrors
..but didn't really like the look of them so changed something a bit different, which i think  suit the car better
Edited by KTS, 25 July 2022 - 08:09 PM.
#263 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 25 July 2022 - 09:23 PM
Cant wait to see this on the road
#264 KTS
KTS
  • 2,421 posts
Posted 25 July 2022 - 10:20 PM
Me too !!  :lol:
#265 ac427
ac427
  • 674 posts
Posted 10 August 2022 - 10:38 AM
..packed out the void with JBweld - hopefully that will keep the grease in the grease tube !
..which meant that i could finally get on and fit these - the reason why I stripped the radius arms in the first place !!
What are these parts for?
Also, where did you go for the aqua blasting?
Edited by ac427, 10 August 2022 - 10:47 AM.
#266 KTS
KTS
  • 2,421 posts
Posted 10 August 2022 - 11:37 AM
They're the grease tubes for the radius arms; but (earlier?) OEM steel ones rather than the typical/aftermarket plastic ones which can split when grease is pumped in to the arms
blasting was done at Stotfold Engineering in Biggleswade
#267 ac427
ac427
  • 674 posts
Posted 10 August 2022 - 01:09 PM
Thanks.
I'm worried about over zealous blasting, was there much debris in the gearbox casing afterwards?
Are the bearing surfaces ok?
Edited by ac427, 10 August 2022 - 01:10 PM.
#268 KTS
KTS
  • 2,421 posts
Posted 10 August 2022 - 01:47 PM
Not a significant amount of debris, but as with anything that's being fitted it needs thoroughly cleaning whether it's new, or reconditioned.
With the casing, most of the debris was in the blind drillings for the diff and transfer case studs/bolts
Bearing surfaces were ok; a little bit of marking to the diff bearing journals, but pretty light. If I was to do it again I might mask them off with gaffer tape for emphasis
The aqua blasting media used was quite hard, so left the surface with a matte finish. Softer media can be used like walnut shell, which is obviously less abrasive and leaves a smoother surface, but takes longer, so costs more
#269 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 12 August 2022 - 11:05 AM
I also have Optimise trim, did you have trouble trying to get the fillet panels in under the door latch and the drain tube? It looks like I may have to cut a bit out of the fillet to miss the drain tube.
I also have bullet type mirrors I intend to fit onto the window
#270 KTS
KTS
  • 2,421 posts
Posted 12 August 2022 - 11:19 AM
I didn't have any issues fitting the fillets - I tucked the drain tubes into the channel that runs down the back of the door to keep it out of the way
Also tagged with one or more of these keywords: pickup
