'81 Pickup
pickup
416 replies to this topic
#181 KTS
KTS
  • 2,423 posts
Posted 18 April 2021 - 07:49 PM
so will need to look at what can be done to tone them down
Might sound daft, but colour the end in with a black Sharpie
Thanks Graeme - I tried a blue one which didn't make much difference. Didn't think to use black...
#182 GraemeC
GraemeC
  • 7,438 posts
Posted 18 April 2021 - 09:25 PM
Might need more than one ‘coat’ too.
it worked for me in my car - the blue ones are particularly bright.
#183 KTS
KTS
  • 2,423 posts
Posted 20 April 2021 - 07:05 PM
i tried a black sharpie, but that still didn't dim it down enough for my liking,so.....
sanded back the ends of the LEDs on the toggles, and put a dab of black paint on with a cotton bud
...now much better
#184 KTS
KTS
  • 2,423 posts
Posted 24 April 2021 - 04:35 PM
still wasn't entirely happy at how bright the lights were, so had another go final attempt at cutting down the brightness of the LED's
this time, completely covered the LED's with black paint and then scraped away a small section in the middle.  happy with that now;  enough to be visible in daylight but not overly bright at night
abandoned any idea of engine turning the cluster facia, and etch primed it ready for paint
Piston installer tool arrived this week, and re-fitted the cleaned up pistons so i could have another go at measuring the crown to deck heights - when i measured them previously i was getting 20 thou variation between the 4 cylinders, now they're all within 4 thou which i'm happy with.  still seeing about 5 thou difference across each piston, which isn't ideal, but will have to do.  interestingly, the difference is in the same plane for all the piston/conrod assemblies.
anyway, now i've got some measurements i'm comfortable with, i can strip the block down again and send away for a very light hone before fitting new piston rings
#185 GraemeC
GraemeC
  • 7,438 posts
Posted 24 April 2021 - 05:15 PM
You could also turn the switch over so they’re pointing down when on - will stop the bright light shining up at you
#186 KTS
KTS
  • 2,423 posts
Posted 24 April 2021 - 06:13 PM
..but that would have been too easy  :lol:
#187 KTS
KTS
  • 2,423 posts
Posted 25 April 2021 - 07:17 PM
Painted the facia plate and supports, re-assembled and fitted it.  Happy with that  :proud:
#188 Maccmike8
Maccmike8
  • 1,101 posts
Posted 25 April 2021 - 08:24 PM
Looks fantastic.
#189 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 27 April 2021 - 12:46 PM
finished off the wiring on the instrument cluster
..and then bench tested it to make sure it all works as expected
testing revealed a couple of issues that need to be addressed; one fairly trivial that a diode will rectify (!), and the other that some of the LED's i've used are really bright; especially the blue one in the toggle switch, so will need to look at what can be done to tone them down
That looks great.
#190 I hate Brian
I hate Brian
  • 782 posts
Posted 27 April 2021 - 03:33 PM
Lots of thought gone in to this well done
#191 KTS
KTS
  • 2,423 posts
Posted 27 April 2021 - 08:29 PM
Thanks. I'm really pleased with how it's turned out so far. Still have to make some kind of cowling for it, but that's a job that'll have to wait for now
#192 panky
panky
  • 1,791 posts
Posted 28 April 2021 - 10:13 AM
Even better turn them sideways and dazzle the passenger :D
I've fitted the same switches and boy are they bright, might pinch you idea with the paint.
#193 KTS
KTS
  • 2,423 posts
Posted 28 April 2021 - 09:28 PM
despite being pleased with how the instrument panel had come out, the AFR gauge stood out as the surround was quite different from the other gauges, so after a bit of work, managed to get a smiths chrome surround on it instead.  now looks much better
#194 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 28 April 2021 - 10:01 PM
Totally agree. That looks much better now.
#195 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 28 April 2021 - 10:13 PM
Very nice
Also tagged with one or more of these keywords: pickup
