'81 Pickup
pickup
416 replies to this topic
#166 KTS
KTS
  • 2,423 posts
Posted 08 April 2021 - 06:21 PM
Result !!  i now have doors that close properly  :D
the solution in the end was to use two different types of door seal; main body of the doors, where the gaps were really tight, is fitted with phoenix trim DX88, and the window frame section i used the much wider DX73 type
#167 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 08 April 2021 - 09:16 PM
Excellent. I will be on that tomorrow! Do you have a link for supplies?
#168 KTS
KTS
  • 2,423 posts
Posted 08 April 2021 - 09:23 PM
Here you are - also worth noting that they sell the floor seals that fits between the load bed and side panels
https://phoenixtrim....i-shop-67-c.asp
#169 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 09 April 2021 - 02:59 PM
What a great project. Looks stunning.
#170 KTS
KTS
  • 2,423 posts
Posted 10 April 2021 - 05:05 PM
brake and clutch masters in and front brake pipework installed
..and made a tool to install the clevis pins out of a paintbrush handle and a magnet from an old phone case - works a treat
#171 KTS
KTS
  • 2,423 posts
Posted 11 April 2021 - 08:34 PM
back to wiring again today, and managed to get the bulk of the instrument cluster loom in place - still need to sort out the earth connections and order some more cable for the last of the line outs, but the hard part is done
Also replaced the durite push-pull switches i fitted initially with illuminated chrome toggle switches which are a big improvement
I was planning to paint the face with black crinkle finish paint, but after watching the last Ivans Shed video on the two cylinder a-series i decided i'm going to have a go at corking the front panel and see how it turns out.
#172 nev100
nev100
  • Just Joined
  • 143 posts
Posted 12 April 2021 - 06:47 AM
Loving this build.
I tried a Crinkle finish for my dashboard. I bought a can from Frost.
I followed the instructions to the letter....but the finish wasn't as good as I'd expected.
I ended it stripping it all off and applying a fake carbon wrap. Looks a lot tidier.
Be interested to hear others experiences of the Crackle paint finish....
I did use it on my heater. Again, not perfect but it's hidden under the dashrail so I'll leave it.
#173 KTS
KTS
  • 2,423 posts
Posted 12 April 2021 - 02:06 PM
Loving this build.
Thanks - glad you're enjoying it
i used the same stuff on my steering wheel boss and after a quick bake in the oven it came out pretty well
#174 Vanman20
Vanman20
  • 274 posts
Posted 12 April 2021 - 02:40 PM
What's corking ?
#175 KTS
KTS
  • 2,423 posts
Posted 12 April 2021 - 03:45 PM
What's corking ?
possibly a made up term i just invented  :shy:
in the video it looked like they were using a piece of cork in a pillar drill to produce the swirl pattern on the control panel
#176 Vanman20
Vanman20
  • 274 posts
Posted 12 April 2021 - 04:05 PM
What's corking ?
Do you mean engine turned ?
https://madaboutmorg...urned-finishes/
#177 KTS
KTS
  • 2,423 posts
Posted 12 April 2021 - 04:42 PM
that's the one !  thanks for the link.
possibly just a piece of wooden dowel is all i need then.  i guess that means i should put that bottle of wine away then  :(
#178 KTS
KTS
  • 2,423 posts
Posted 18 April 2021 - 06:17 PM
finished off the wiring on the instrument cluster
..and then bench tested it to make sure it all works as expected
testing revealed a couple of issues that need to be addressed; one fairly trivial that a diode will rectify (!), and the other that some of the LED's i've used are really bright; especially the blue one in the toggle switch, so will need to look at what can be done to tone them down
#179 g111mds
g111mds
  • 432 posts
Posted 18 April 2021 - 06:29 PM
Really nice work on this - stunning!
#180 GraemeC
GraemeC
  • 7,438 posts
Posted 18 April 2021 - 07:18 PM
Might sound daft, but colour the end in with a black Sharpie
Also tagged with one or more of these keywords: pickup
