I Can't Get The Brake Light Switch To Turn Off
Best Answer noeman , 12 April 2019 - 03:30 PM
Thanks guys for your replys, but I've answered my own question. After staring at it, I worked out if you loosen the bolt of the bracket the switch is bolted to you can slide it back or forth for adjustment. Mine was too far forward.
Hope that helps others too. Go to the full post
5 replies to this topic
#1 noeman
noeman
  • 125 posts
Posted 12 April 2019 - 10:08 AM
My brake lights are permanently on. It is the switch by the pedal, the brake pedal doesn't come up enough to press the switch off. I've completely screwed the switch in as far as it can go and still no joy. I even bought a new lucas switch to see if it would screw in further but its still the same.
I wondered if there was any other adjustment to get the switch a little closer to the brake pedal?
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 12 April 2019 - 10:46 AM
You can extend the rod behind the servo (if you have one) to move the pedal. Not sure, if you have a yellow label master cylinder as ive never worked on them.
#3 smurfomatic
smurfomatic
  • 460 posts
Posted 12 April 2019 - 11:28 AM
Just had to change the switch on mine (it was stuck). The old one had a small screw fitted into the end of the plunger to extend it, so I have done the same on the new one and it works fine.
#4 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 12 April 2019 - 11:38 AM
Its odd as I've had to trim some off the end of mine as the brake lights don't come on unless you put your foot almost through the floor!
#5 noeman
noeman
  • 125 posts
Posted 12 April 2019 - 03:30 PM   Best Answer
#6 Spider
  • 14,838 posts
Posted 12 April 2019 - 06:38 PM
The UK cars are made different to the Aust ones in this regards.
Our bracket was welded, but is rather long. To adjust it, you just bend the bracket a little one way or the other, as required.
