Posted 11 April 2019 - 06:51 PM
Posted 11 April 2019 - 07:53 PM
I usually fit them right before the Carb.
Posted 11 April 2019 - 09:00 PM
Posted 12 April 2019 - 07:18 AM
Posted 12 April 2019 - 07:40 AM
as the crap should really be stopped before it enters the pump I have one before the pump.
Posted 12 April 2019 - 08:11 AM
either place or me. but a filter is a very good idea! much easier to change a small inexpensive filter than to clean out the carburetor
Posted 12 April 2019 - 08:12 AM
All the more reason to have a Morris Minor pump on the bulkhead.
Posted 12 April 2019 - 09:08 AM
With the diaphragm type Electric Pumps, like the SU, that's asking for a burnt out pump.
If the filter blocks (and doesn't have to do so completely), it will stall in an energised state. The Coils are only short time rated, so they will burn out.
They are designed - to a point- to pass some debris without issue.
Posted 12 April 2019 - 09:28 AM
I'll believe you, but in my experience, if the inlet is blocked, the pump just keeps pumping away like a machine gun.
If the filter is transparent, the amount of debris needed to block it, should be noticeable.
Posted 12 April 2019 - 09:45 AM
Fair enough if that's been your experience, but I would say, that in order for it to pump away like that, either there's another fault or air is getting in on the suction side somewhere.
My own experience, both on my own cars and those of customers (when in the trade) is they do burn out.
" Blockage
Should the pump labour whether the fuel tank line is connected or not, then there is blockage in the suction side of the pump and the first stage is to clean the fuel filters in the pump. If the pump then strokes freely while still disconnected and labours on re-coupling the fuel tank line, then there is obstruction in that fuel line which can best be cleaned by cleaning the fuel tank and fuel line filters (if fitted) and by blowing compressed air down the fuel line from the pump end. The best way to tell whether a pump is labouring or merely stroking slowly (as at idling engine speed) is to feel it - if the pump is hot (taking into consideration the normal temperature and not forgetting the influence of engine heat) then the pump is labouring. These pumps will still function even when they are so hot that it is unbearable for the hand to remain touching. Removal of the end cover and observation of the contact points will also show whether the pump is labouring - if it is, the points will be closed for most of the time. It is very bad indeed to allow these plumps to overheat because the coil insulation may break down and if it does, then possibly
the most expensive part of the pump has failed. "
from here http://www.da7c.co.u...p servicing.htm
While this guy says they will work when quite hot (and then eventually burn out) because of the location of the pumps and how quiet they run, one doesn't know there's a blockage until it's burnt out.
Posted 12 April 2019 - 11:19 AM
Well I can't argue with that, but for my own satisfaction, after grandchildren's Easter holidays are over, I'll go through some boxes and sort one out.
May we conclude, that there should not be a dirty filter between the tank and the pump, and if filtered fuel to the carb is required, that the place for a filter is between the pump and the carb ?
Posted 12 April 2019 - 06:47 PM
Yes, of course, but I think we'll also agree that regardless of where one chooses to fit a filter, it does need to be checked and periodically, replaced.
I am a believer in replacing them about once a year as there's always some tiny amount of moisture in petrol and most filters are paper based, the moisture does make the paper swell and they can block from that, or at the least, reduce flow.
I've seen the glass types that have a gauze in them (that I think you also referred to a few posts back). I'm not sure what's available in the UK in these types, but the ones that seem to be sold here and very poor as a filter, the gauze is too big to be of any use.
Posted 12 April 2019 - 07:11 PM
The gauze in modern glass water traps in UK is not as fine as it was 50 years ago.
Posted 13 April 2019 - 04:27 PM
Any recommendations on the best filters to use?
Posted 13 April 2019 - 06:01 PM
Ask an MOT tester for one ?
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
