Mpi Horn Issue
#16
Posted 08 April 2019 - 05:01 PM
#17
Posted 08 April 2019 - 05:11 PM
Yep horn works fine out of the car.....
#18
Posted 08 April 2019 - 05:18 PM
Item 25
http://www.minispare....aspx?2~20~201'
Edited by Wiggy, 08 April 2019 - 05:19 PM.
#19
Posted 08 April 2019 - 05:42 PM
Horn not working, Help.......
Horn has been tested and works out of the car. I have 7 volts when the horn button is pushed with the horn removed.
Relay clicks and I have replaced it with a new one.
Anyone have any ideas?
I have a new relay and have swapped relays....
Edited by toplessmini, 08 April 2019 - 05:42 PM.
#20
Posted 08 April 2019 - 06:09 PM
You've tested all the component parts, so it has to be the wiring.
Have you cleaned up the earth behind the expansion tank? It's a multi earth point.
#21
Posted 08 April 2019 - 08:32 PM
I have 12v present on pin 87 of the relay (output) and 12v to the horn (with the horn removed) when the buttons on the steering wheel are pressed.
With the horn in place using the same earth as the previous test I have 0v at the horn.
Pins 30 and 85 are constant 12v live feed via the 20amp fuse.
Pin 86 is connected to the steering wheel switches and the alarm.
When the switches are used or the alarm is activated the relay is energised (clicks).
Edited by toplessmini, 08 April 2019 - 08:50 PM.
#22
Posted 08 April 2019 - 09:28 PM
#23
Posted 08 April 2019 - 09:58 PM
The horn is earthed via the bracket it is mounted on to the body work.
I have had the horn earthed via an earth strap coming directly from the alternator, when it was removed from the car.
The same earth strap connects to the body work at the same point as the bracket that holds the horn.
#24
Posted 08 April 2019 - 10:50 PM
#25
Posted 01 May 2019 - 12:14 AM
Horn is now working, I've bypassed the feed from the relay by disconnecting the original feed and running a new one.
