Horn not working, Help.......
Horn has been tested and works out of the car. I have 7 volts when the horn button is pushed with the horn removed.
Relay clicks and I have replaced it with a new one.
Anyone have any ideas?
Posted 01 April 2019 - 06:18 PM
Posted 01 April 2019 - 06:49 PM
Posted 01 April 2019 - 06:55 PM
Definitely not the earth, that's all good. No other issues i'm aware of.
Gonna check the steering column next...
Posted 01 April 2019 - 07:02 PM
Perhaps it is the rotary coupler behind the steering wheel?
That seems like a good place to start. I believe they are the same as other MG/Rover so getting a replacement should't be an issue if required.
I think that the Horn shares a fuse with the alarm system so is that working? Although I assume that you would have already checked that.
Ben
Posted 01 April 2019 - 07:06 PM
I've checked the 20Amp fuse, alarm works minus the horn.
Rotary coupler is my next port of call, I just need to find out what that is lol...
Posted 01 April 2019 - 07:09 PM
Remove the airbag and then the wheel and it sits on the column behind the wheel.
It's like a plastic chunky disc with a clock spring inside it and wiring.
Make sure you disconnect the battery for a while before touching the airbag though and try not to rotate the rotary coupler. If you do, make sure you return it back to the same position before putting back together or you may end up with the SRS light on and a broken clock spring.
I have one at the garage out of the Pink MPI if you want to borrow it to test with?
Ben
Posted 01 April 2019 - 07:16 PM
Thanks Ben, how do you remove the airbag?
Posted 01 April 2019 - 07:55 PM
Ill link this to save typing it all out.
Hopefully it will help you
http://www.theminifo...ir-bag-removal/
Ben
Posted 01 April 2019 - 08:33 PM
Thanks again Ben, I've managed to remove the wheel and YRC100300 rotary coupler....
Posted 01 April 2019 - 08:40 PM
Now the wheel is off I need to find a nice wooden MGF airbag wheel, I think it will look good...
Edited by toplessmini, 01 April 2019 - 08:41 PM.
Posted 01 April 2019 - 09:52 PM
Yep I've been looking at that one but seems pricey.....
Posted 02 April 2019 - 05:06 AM
Posted 02 April 2019 - 08:33 PM
Posted 08 April 2019 - 04:58 PM
So new rotary coupler in place and still no horn.
I did set the alarm off a few days ago and no sound from the horn but the indicators still flashed.....
