Fuel Line Size
12 replies to this topic
#1 Toffe98
Toffe98
  • 30 posts
  • Local Club: Mini Club Flying Finns
Posted 26 March 2019 - 07:04 PM
Hi!
Wondering about what fuel line to get for the Mini. I know the stock line is 6mm od (5/16") but if I want to upgrade the carburettor and possibly cylinder head in the near future, will 6mm be enough or should I fit an 8mm already? And what about 10mm, is that too big? 10mm is the size I could get probably the easiest, atleast a lot easier than 8mm. But if 6mm will be enough for a "fast road" car with a big bore head and probably an hif44 carb then that's probably what I'll go for, and maybe upgrade if I decide to supercharge the car at some point. Oh and the current configuration is an almost stock 1293cc engine with an hs4 carb, almost stock meaning that it's just bored to 1293 and has a slightly faster cam in it.
And any opinions on what material the fuel lines should be? If going with a 6mm I think copper is the only option but for 8mm and 10mm theres both copper and aluminium available.
- Toffe
#2 Stu1961
Stu1961
  • 633 posts
  • Local Club: Still Looking
Posted 26 March 2019 - 09:19 PM
I would imagine the stock size as you call it would be sufficent even for a HIF44 which is 1/4" o/d x 22SWG, SWG figure refers to the wall thickness (0.028") Cupro nickel would be the most suitable material as it pretty much corrosion resistant and is better than copper with regards to its ability to resist fatigue. 6mm o/d tube maybe a little restrictive as it may well be a smaller bore than the 1/4" tube.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 26 March 2019 - 09:35 PM
If in the UK one can get a roll of 8mm (ID) microbore boiler pipe, i use this on my minis
#4 Avtovaz
Avtovaz
  • 1,232 posts
Posted 26 March 2019 - 09:54 PM
You can get it for gas i think it is too, its plastic coated, i use it on my rally car.
Edit
click here
Edited by Avtovaz, 26 March 2019 - 09:56 PM.
#5 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 26 March 2019 - 10:34 PM
Edit
click here
That does the job at double the price
#6 DeadSquare
DeadSquare
  • 3,089 posts
Posted 27 March 2019 - 09:34 AM
A 3 liter V6 Ford Capri only has a 1/4" fuel line,   .....................   unlike one race car which got round the NASCAR regulation size fuel tank by having a 9" fuel pipe !.
Edited by DeadSquare, 27 March 2019 - 09:34 AM.
#7 Toffe98
Toffe98
  • 30 posts
Posted 27 March 2019 - 01:08 PM
So if I'd go for the plastic coated 8mm copper pipe, what fittings should I use to connect the steel braided pipe that connects it to the tank and the fuel pump? Oh and of course I meant that the stock size is 6mm = 1/4", not 5/16" as I said.
#8 Avtovaz
Avtovaz
  • 1,232 posts
Posted 27 March 2019 - 01:11 PM
On the rally car I’ve used a stretching tool , does the same job as ramming a screw driver into it to stretch it out . Then I’ve just clipped onto that with rubber pipe , and a juberlee clip . That’s on high pressure injection too
#9 nicklouse
  • 18,577 posts
Posted 27 March 2019 - 01:13 PM
to be honest there is no reason to fit anything larger than the outlet of the tank.  and then just some suitable rubber fuel hose.
#10 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 27 March 2019 - 01:24 PM
I looked at hard lines on Merlin Motorsport a while ago, it was much more expensive than that copper pipe.
Is there any benefit to using the stuff sold by Motorsport companies, rather than something cheaper?
#11 DeadSquare
DeadSquare
  • 3,089 posts
Posted 27 March 2019 - 02:10 PM
If you use 99% pure copper tubing, you MUST protect it from road salt.
8mm OD Kunifer brake pipe is 90% Copper - 10% Nickel and is not attacked by Sodium Chloride.
Because I can easily obtain it, I now use the plastic pipe for pressurising beer kegs with carbon dioxide.  For added safety I thread it through a stainless steel tube that runs inside the car.
#12 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 27 March 2019 - 03:16 PM
^this.
To put it into perspective, many turbo minis are running stock lines and fueling for 160bhp+.
#13 Toffe98
Toffe98
  • 30 posts
Posted 27 March 2019 - 03:23 PM
Thanks everyone for the replies!
^this.
I think I'll go with this advice and just get some 6mm copper tubing and probably protect it somehow. The road salt isn't too big of a problem for me because I won't be driving in the winter here in Finland anyway, but it's probably no harm in protecting it anyway.
