Fitting An Electric Fan On Mk1
50 replies to this topic
#46 beardylondon
beardylondon
  • 1,795 posts
Posted 10 May 2019 - 07:02 AM
Thanks All.
I have a cowl, even painted body colour, but for various reasons it never fitted, so I removed it. So I'm now thinking of modifying the cowl and fitting it, with a Minispares fan on the Rad, to get maximum efficiency. Decisions, decisions!
#47 cooperd70
cooperd70
  • 793 posts
Posted 10 May 2019 - 07:38 AM
Thanks All.
My cowl is the one for the later cars that fits to the engine side of the radiator.
Maybe readying yourself for queues of minis during this year's 60th celebrations ?
#48 beardylondon
beardylondon
  • 1,795 posts
Posted 10 May 2019 - 08:03 AM
I have the engine side cowl, Im talking about the wing side cowl that was fitted to Mk1s.
Edited by beardylondon, 10 May 2019 - 08:12 AM.
#49 beardylondon
beardylondon
  • 1,795 posts
Posted 07 June 2019 - 04:50 PM
The fan is in and working, thanks to everyone for their help, especially Phillrulz who's wiring guidance was greatly appreciated.
I took Phil's advice and put in an additional relay, with a fuse, (convo happened on another thread), you can see below, top part is Phil's and bottom is wiring diagram from the Minispares Revotec kit.
I am a bit peeved their wiring instructions didn't explain it properly, I know they can't cater for all, but some clearer explanation would have helped. Especially as to why you should have a switched live, it would have saved a lot of head scratching, especially considering this is meant to be a ready made kit for a Mini. They didn't include the earth wire from the fan, talk about penny pinching.
I couldn't use their brackets to attach straight to the rad, as there wasn't enough room in the engine bay, so my Dad kindly made some brackets to attached to the inner wing. They will be painted, shown unpainted in the test fit photos below. Similar to Azbornmini's brackets, some steel and some 3/4" tap washers from Screwfix, which are 25mm wide and drilled out to fit the M8 bolts, which I had to buy.
I can confirm it works fine in the wing and disperses heat very well.
Edited by beardylondon, 07 June 2019 - 07:36 PM.
#50 cooperd70
cooperd70
  • 793 posts
Posted 07 June 2019 - 08:01 PM
Glad you have it sorted! You can keep the Min cool all summer long ?
#51 Azbornmini
Azbornmini
  • 93 posts
  • Local Club: Classic Minis of Arizona
Posted 09 June 2019 - 01:48 AM
Nice setup!  Like your mounts.  Well sorted wiring.  I think my brother and I are going to mount oil temp sensors this summer in our Minis.  We do have oil coolers mounted, but really it's only getting up to about 105° this week, do we really need them?   :tumble:
