Fitting An Electric Fan On Mk1
50 replies to this topic
#16 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 26 March 2019 - 07:06 PM
That one looks good and should work fine.
I have one on my Mk.1 Cooper 'S' and it is mounted onto the inner wing on the outside, i.e. under the wheel arch. It is very effective in traffic on hot days and just keeps the temp at a sensible level.
My recommendation is to have it manually switched and to fit a capillary-type gauge which gives an accurate temp reading in degrees, then you will know when to switch the fan on. I have a warning light next to the fan switch as well and I have it switched so that I can leave it on with the engine switched off and the key removed.
Make sure you fir it to 'suck' the air out of the engine bay and not blow it back in. Sorry if that's a bit of a basic thing to say, but I did see one which was intended for a front radiator Ford and it had been put on a Mini to work 'backwards'  ;D .
That's exactly what i want to do.  Would you be able to post a few pics under the wheel arch??
Paul
#17 floormanager
floormanager
  • 804 posts
Posted 26 March 2019 - 07:39 PM
also, did you use a relay to switch on the fan?
Thanks,
Paul
#18 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 26 March 2019 - 09:10 PM
A relay would be a very good idea. Thermo fans take a lot of current and you don't want all the current running through the switch
#19 nicklouse
  • 19,062 posts
Posted 26 March 2019 - 09:25 PM
Thanks,
Paul
do so.
#20 Cooperman
  • 23,568 posts
Posted 26 March 2019 - 11:10 PM
Yes, I always use a relay for any electrical item which has a high power requirement.
I also use a 6-blade 'export' fan on my 'S', although on the 1990 Cooper 1275 rally car I have an 11-blade is fitted.
#21 carbon
carbon
  • 2,590 posts
Posted 28 March 2019 - 07:28 PM
brand new rebuilt engine, 750 miles on the clock. thermostat was dodgy, replaced that recently with one that I know works.
Would suggest also checking the ignition timing.
In my experience if there not enough advance at idle the engine will run much hotter.
#22 beardylondon
beardylondon
  • 1,798 posts
Posted 29 March 2019 - 12:17 PM
Thanks all.
Am going to fit a new thermostat, and advance the timing.
I noticed the thermostat I had in didn't have the bleed hole, like my new one does, would that have caused a pressure build up?
#23 cooperd70
cooperd70
  • 793 posts
Posted 29 March 2019 - 12:33 PM
I have several. Some do and some don't. No sure if it would be the cause though.
#24 mini13
mini13
  • 3,811 posts
Posted 29 March 2019 - 12:45 PM
Thanks all.
it could trap air, i would always stick a small hole in there just to air can get through so the system will beed itself, 3mm would be fine
#25 beardylondon
beardylondon
  • 1,798 posts
Posted 29 March 2019 - 02:03 PM
Well I have fitted that one with the hole it in, so we'll see!
#26 beardylondon
beardylondon
  • 1,798 posts
Posted 03 April 2019 - 07:55 PM
Well it seems to run colder in traffic now, maybe that new thermostat fixed it. It will be interesting to see what it does in hotter weather!
#27 beardylondon
beardylondon
  • 1,798 posts
Posted 30 April 2019 - 08:35 PM
Hi Cooperman
Please can you point me in the right direction for which relay I need?
#28 Cooperman
  • 23,568 posts
Posted 30 April 2019 - 09:32 PM
I normally use a Bosche 450880030. It is 25 to 30 amp which is ideal for the fan. Don't forget to run the supply cable through a fuse. I suggest a 12 amp fuse.
#29 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 01 May 2019 - 01:51 AM
You can also get fused relays like these which combine the fuse and relay into one unit
https://www.autobarn...de-fuse-68060bl
#30 beardylondon
beardylondon
  • 1,798 posts
Posted 01 May 2019 - 07:14 PM
thank you!
