Hovercraft Mini
3 replies to this topic
#1 mab01uk
mab01uk
  • 12,391 posts
Posted 23 March 2019 - 12:12 PM
"What looks like a Domino shell has been turned into a hovercraft. In the front a Briggs and Stratton engine provides lift, whilst a Citroën 2CV engine drives the propulsion fan at the rear. The machine can be seen at the Hovercraft Museum, Lee-on-the-Solent."
https://www.minimarc...mini/index.html
Hovercraft Museum:-
https://www.hovercraft-museum.org/
#2 nicklouse
  • 18,524 posts
Posted 23 March 2019 - 12:58 PM
we used a rotax KEC125 for lift and a Fiat 126 for thrust on our build back in 85.
#3 nicklouse
  • 18,524 posts
Posted 28 March 2019 - 12:39 AM
Attached File  217614_5426668170_3225_n.jpg   58.66K   0 downloads
on lake Windermere
#4 DeadSquare
DeadSquare
  • 3,088 posts
Posted 28 March 2019 - 01:00 AM
After a very, very wet winter, I used a Rover V8 for lift on an 8' X 20' "Low Ground Pressure" fertilizer spreader.   I had to have wheels to maintain a constant forward speed and to cope with undulating ground, so I used a WV engine and box, which also powered the spreader.
It worked after a fashion, but I never overcame the problem of weight transfer as the load reduced.
I worked much better as a sprayer because I had a tank either end, but then the drawback was that the water had to be taken to the sprayer in the field, not the sprayer to the water.
