Hi Everyone,
Any suggestions on how I can check push rods for straightness?
Thanks from the Pied Pipers Town
Posted 21 March 2019 - 07:15 AM
Hi Everyone,
Posted 21 March 2019 - 07:37 AM
Spin them slowly in a lathe and clock them with a gauge.
A bent push rod should be replaced and only straightened in an emergency to "get you home" .
Posted 21 March 2019 - 08:44 AM
Hi Everyone,
I just spin them in my fingers and you can see it.
Or, put one end on a table and do the same (between the fingers on the other end).
When they bend, they really bend !
Posted 21 March 2019 - 10:26 AM
You'd have to go outside the elastic limit to bend one permanently and that will be pretty obvious.
Posted 21 March 2019 - 12:06 PM
Posted 21 March 2019 - 12:26 PM
Posted 21 March 2019 - 03:39 PM
Guys,
You are incredible. Since I have no lathe, I will try the method suggested by Moke Spider. What I'm concerned about, is not so much bending in use, but in storage. Back in the day I used to race a Mk1 Fiesta with a Kent 1150 cc engine, which is quite similar to the A-series and with a minimum budget and lots of used and abused spares available, selecting the right parts was the recipe for reliability.
Then don't store them in a flimsy box on the floor where you will tread on them.
If you are just going to 'roll them', do it on a horizontal mirror and get your eye down as close as you can to mirror level.
