Question About Gearbox Bearings For Rebuild
32 replies to this topic
#31 Inno
Inno
  • 138 posts
Posted 22 March 2019 - 05:57 PM
While browsing last few hours searching for bearings  :D  :D  I actually completed this table that contains all parts from Guessworks full kit for A+ gearbox and diff.
Their most complete package contains only one idler gear bearing and doesn't contain 1st, 2nd and 3rd gear bearing. Parts that they offer in their kit are not the cheapest one, on contrary....although with TMF+ discount prices there and in Minispares are very similar....
Gearbox  parts
Minispares
Guess
Oil central sump
C-AHT54
Gearbox gasket set
AJM804B
Clutch oil seal performance
13H2934 (MS)
Layshaft  performance
C-22A1739
Layshaft thrust washers & shims
1 large layshaft needle roller
CHM141
2 x 1st motion shaft and layshaft needle roller
13H9513
1 double roller bearing
AAU1365
1 single roller bearing
ADU7619
2 idler gear bearing
TUK100320
Only one
4 Baulk rings
C-22A1741
6 x Synchro springs and balls
22G2262
BLS107
Rod change bush + o ring
31B447
ROLLER 1st MOTION SHAFT PILOT TO CLUTCH CASE
AAU8424
Pilot bearing nose circlip
CCN110
O RING ON ROD CHANGE SHAFT BUSH
CDU1563
 x 1 - 1/4" UNF Nyloc nut
GHF221
x 1 - 3/8" UNF Nyloc nut
GHF223
1st gear needle roller
AAU1815
N/A
2 x 2nd/3rd gear needle roller
AAU1816
N/A
DIFF
2 diff bearings
AHU1856
2 x seal for Dif
ADU5738
2 x Planet gear
Dam6624
2 x Planet gear thrust washers with lip
DAM5071
2 X DIFF thrust washers
BTA101
Diff pin molybdenum coating
C-BTA164
#32 Inno
Inno
  • 138 posts
Posted 22 March 2019 - 05:58 PM
...it was a table....but it disappeared ... O_O
#33 gazza82
gazza82
  • 3,004 posts
  • Local Club: TMF+
Posted 24 March 2019 - 11:19 PM
It will ... you can't copy a table to a forum page
