12H159C-H5542
i think alegro but can anybody tell me more ?
thanks
Posted 10 March 2019 - 06:32 AM
12H159C-H5542
thanks
Posted 10 March 2019 - 07:11 AM
http://www.theminifo...-numbers/page-2
Have a read on the remainder of the article as well
I expect someone will be able to nail it a bit closer
Edited by richmondclassicsnorthwales, 10 March 2019 - 07:14 AM.
Posted 10 March 2019 - 11:57 AM
the front plate gives it away. but yes not originally from a Mini and from what i can see it is likely to be allegro.
Posted 10 March 2019 - 04:56 PM
12H159C-H5542
Not easy as you've only supplied an engine number & 1 fuzzy photo.... Engine casting numbers?, number of head studs/bolts?, cylinder head numbers/stamped numbers? etc.
There are vague references to 12H159C being an early 70BHP(?) Allegro number
....but most info points to this being from a 1967-72 ADO16 MG1300 or Riley 1300 (on a later rod change gearbox).
12H = horizontal 1275cc
159 = Lucas C40/1 dynamo, all speed synchromesh remote gearbox,
C = positive crank case ventilation , twin hs2 carburetors
H = high compression
Normally MG/Riley engine numbers start with 12G -but thanks to Supersonic(Mk1 forum), mab01uk, & Moke Spider it's been shown that some start with 12H.
Is it a 11 stud block? & is the cylinder head stamped by the thermostat 12G1805? ....If so then it's almost definitely the ADO16 MG/Riley engine.
Posted 11 March 2019 - 04:41 AM
sorry cant get head information,
these are all the photos.
next question is will it fit into a mini or what's involved
Posted 11 March 2019 - 05:37 AM
Posted 11 March 2019 - 05:58 AM
Posted 11 March 2019 - 09:42 AM
Ok now we can see more of it I would say it was a engine swap onto existing box. and just a 1275 engine nothing special.
needs a strip and check but should be fun.
Posted 11 March 2019 - 11:32 AM
This is is not an MG 1300 or Riley unit. A few early ones had 12G prefix engine numbers but the vast majority of those 70bhp units had the 12H prefix, but they would not have had the 159C code.
Blast! That's a shame. I found 1 reference to 159C being a standard ADO16 1275.... but 2 references to it being a twin carb version.
Just found something today -would the code for the 70bhp units be 298F???? (Lucas C40 dynamo, S type design variants, Close ratio remote control gearbox, Carburettor crankcase ventilation and twin carbs).
.... & do you know of any online websites that give a complete list of ADO16 engine numbers?
It appears to have the wrong transfer case too as its not drilled and tapped for a crankcase breather.
Yep, i noticed some anomalies but didn't want to complicate matters further (& were they fitted before 1971?)
My 12G1279 11stud engine has a 12G1938 clutch case breather but i can't remember if it originally had a timing cover breather (oh well,it has now).
Posted 11 March 2019 - 03:44 PM
Posted 12 March 2019 - 07:44 AM
thanks for that, so austin 1300 should be a straight bolt in? I currently have a 1000 but have been looking out for 1275 which seem to be getting harder to find, this has poped up and im trying to work out if it is worth it.
the description was as follows
"Has been stored in a garage out of weather but not out of dust! Was intended to be a racing mini motor, but to the best of my knowledge is stock standard, and was not modified or touched. "
"o the best of my knowledge this was either purchased as a back up motor to be done up for racing, or removed from a body and kept as a backup. The time frame would be around 2002-2005, I'm sorry I cannot be more precise. Since then it has been kept in storage, undercover, and at some stage, still in the garage, but uncovered, hence the surface dirt and dust"
The 1st 1275 engine I bought back in 1985 was from a 1967 austin 1300, it had an open breather on the transfer housing. I'm still running that transfer housing and breather today. You can just see it in the photo if you zoom in.
would this fit the original engine mounts?
Posted 12 March 2019 - 09:04 AM
it has already been in a Mini.
Posted 12 March 2019 - 10:38 AM
Posted 12 March 2019 - 12:44 PM
'Belt and braces' but later 1300GT's of course featured crank case breathers on both the transfer case and the timing cover with a 'T' piece joiner. Presume you are using a single piece cowling but how do you get on with the space (or lack of it) at the radiator end on a Mini with the timing cover baked bean can breather filling what space there is?Yep, i noticed some anomalies but didn't want to complicate matters further (& were they fitted before 1971?)
It's fair to say 12G1938 clutch case breathers are rather elusive!
Roger
