1275 Metro Engine Project
457 replies to this topic
#106 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 29 September 2019 - 06:01 PM
1. Do I need to put assembly lube under the bearing shells, I am assuming not?
Between bearing and cap/block? No.
2. One of the holes in the bearing shell is offset to the hole underneath in the lower main bearing cup, I believe its on the flywheel end - see pic below.
Pretty standard.  You could widen the hole in the clock to match the bearing and in an highly tuned motor this would be advisable.  For a good road motor I think you have enough free passage.
3. One of the oil holes in the centre main bearing lower cup has what looks like a brass insert, the rest do not?
Normal - leave it be.
4. Do I need to lube the thrust washers?
Yes
5. End float is 6 thou so what thrust washers do i need, +3 thou oversize, as this would bring the end float down to 3 thou?
6 thou with standard thrusts in?  If so then yes, get a +3 thou set and re-measure it you are aiming for 3 thou endfloat - note you may only need half the +3 thou set (ie on one side of the crank only).
Thanks for the responses.
Ref the Thrust Washers, I am not sure if these are standard so I guess I should measure them - what size are the standard washers?
Hadn't even thought about using half a set, I assumed that if you bought a +3 thou set each washers would have been +1.5 thou?
#107 GraemeC
GraemeC
  • 7,438 posts
Posted 29 September 2019 - 07:16 PM
What thrusts are you using to measure the endfloat? They are normally stamped on the back, but I’m presuming they’re not new and hence could be worn.
In which case buy a set of new ones and measure again, or measure what you have and compare to the thickness of std ones (I don’t know what this is, but AC probably will).
#108 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 September 2019 - 08:57 PM
You can relieve the shell to bring it into alignment with a small file and extreme care so you dont bend the shell. Whenever I've built a mini engine (2x 998 ministox engines) I've always done this and the engines haven't let the driver down.
So a round needle file to ovalise the hole in the bearing?
#109 DeadSquare
DeadSquare
  • 3,089 posts
Posted 29 September 2019 - 11:02 PM
If you look at the oil ways in the crank, they are countersunk.  I put a countersink in an electric drill, and from underneath, pushing upwards so that the swarf doesn't fall into the block, countersink the offending oil ways in the block;  a lot easier than a needle file ovalising holes in a bearing shell.
#110 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 30 September 2019 - 07:55 AM
Oil is under pressure so it will get to the bearing shells without tampering with them ... I think every A-series is exactly the same ..
#111 mini13
mini13
  • 3,810 posts
Posted 30 September 2019 - 10:27 AM
If tis fairly standard I'd leave the oilways alone, if your building a trackday screamer then i'd chamfer/file them a bit to align them.
in terms of lube, alweays lube any sliding face with assy lube exept the rings whic i would do with oil, although some ring manufacturers give other instructions whoch you should follow, ie IIRC total seal say wd40.
for berting to block/rod faces i always put a bit of somthing there to prevent rust, a wipe of oil, even wd40.
#112 Cooperman
  • 23,278 posts
Posted 30 September 2019 - 12:00 PM
That oilway will be fine.
#113 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 01 October 2019 - 08:26 PM
OK next up - checking the Deck Height.
So I put one piston onto Conrod No 1 using a linished down Gudgeon Pin.
And cut of some perspex pipe and fitted it over the bolt ends.
But I could not work out which way around they should go - is this correct?
After getting the Piston to TDC, I used two methods, first of all I used a steel ruler held on its side and a feeler gauge and then a DTI gauge:
After placing the DTI gauge on the block and setting it to zero, I carefully undid the magnet and slid the mount around so that the needle dropped onto the piston crown.
With both the feeler gauge method and the DTI gauge the piston measured 0.0175" down the block. When using the DTO gauge I gently rotated the crank slightly to ensure that piston was at its maximum height.
So 12.5 thou to come off of the deck, to give me a deck height of 5 thou or 15.5 thou to flush the pistons, for an extra couple of HP?
Does it matter which way you spin the Crank?
Edited by JonnyAlpha, 01 October 2019 - 08:27 PM.
#114 grizzler73
grizzler73
  • 300 posts
Posted 01 October 2019 - 10:43 PM
What CR are you aiming at? Check the chamber volume,Do those calculations before any skimming.
#115 GraemeC
GraemeC
  • 7,438 posts
Posted 02 October 2019 - 05:48 AM
You need to check all 4 and mark which rod and which piston was used in each bore. The next one may only be 0.009” down the bore so if you take your 12.5 thou off it would end up protruding.
#116 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 02 October 2019 - 05:54 AM
Sorry yes I had planned on all four, only managed one last night though.
#117 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 02 October 2019 - 06:53 AM
9.75
Already worked this out with a 5 thou deck height I need around 25cc (maybe less as the calculator does not allow for ring landing) in the chamber (currently 21.4 ish).
CR Calculator
#118 DeadSquare
DeadSquare
  • 3,089 posts
Posted 02 October 2019 - 08:04 AM
If there is a difference, you will have to have a "step" on the surface of the block.
Wouldn't it be easier to work out the different piston heights and make an allowance by how much is polished from the corresponding combustion chamber to compensate the compression volume ?.
#119 mini13
mini13
  • 3,810 posts
Posted 02 October 2019 - 12:13 PM
Eh? for that to work the head would have to be in 4 bits so it could sit at different heights for each cylinder.
Obviosly what needs to happen is to check all 4 in one cylinder, then swap the pistons around to even up the heights, then try them in all the cylinders and asign them so they all sit closest to the same height, then deck it accourdingly.
#120 Dusky
Dusky
  • 5,322 posts
Posted 02 October 2019 - 12:53 PM
Well to get it perfect you deck it to the height of the lowest piston, then machine the pistons accordingly.
