1275 Metro Engine Project
457 replies to this topic
#451 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 04 August 2023 - 08:41 PM
Lose the bottom manifold bracket. Not needed and trash the casing. If you insist on keeping it loose the bolt and fit a stud and a nut. Fitting the stud through the bracket and screwing home then fit the nut. If you don’t, expect to lose some threads.
Do you mean this bracket.
#452 mad4classics
mad4classics
  • 200 posts
Posted 05 August 2023 - 09:58 AM
Personally I wouldn't bolt the strap to a single bolt on the casing.
Either use bracket GEX7526 which picks up on two bolts or bracket GEX7088 (if you can find one) which picks up on three bolts.
http://www.minispare...26.aspx|Back to
Edited by mad4classics, 05 August 2023 - 10:10 AM.
#453 nicklouse
  • 18,689 posts
Posted 05 August 2023 - 12:33 PM
Yep.
#454 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 13 May 2024 - 08:33 PM
Next job was to make some new Timing Teeth, as I had to chop the standard ones off so I could see the Crank Sensor.
Firts I made up a cardboard template:
Then, using a spare timing chain cover, I folded the piece I have cut out to fit and marked and drilled the holes for the bolts to hold it in place.
Then having made an exact template of the original teeth, I marked transferred the outline onto the new marker and cut them out.
I had a bit of a mishap when cutting the teeth:
And here is the finished item:
Now that I had fitted new timing teeth in a different position, I would have to make a new timing mark on the Crank Pulley. To do this I removed No 1 Spark Plug and rotated the engine until it was on its firing cycle and then fitted the piston stop to mark just before and just after TDC. Then I could measure the distance and half it to mark exact TDC, as I had done previously (No pics sorry).
#455 nicklouse
  • 18,689 posts
Posted 13 May 2024 - 09:06 PM
Sorry pointless. You only need a single point marker at TDC. and a half decent strobe gun with an adjustable dial.
#456 Shooter63
Shooter63
  • 1,068 posts
Posted 14 May 2024 - 05:00 PM
I think Nicklouse might be talking about something like this, which I made for my latest engine build.
Shooter
#457 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 25 May 2024 - 02:03 PM
So I lost 1/2 pint of blood for no reason  :lol:
#458 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 25 May 2024 - 02:04 PM
Shooter
Now that's an idea :-)
    Bing (2)
