Converting Mk1 Hydraulic Brake Light Switch To Electric Post 76 Type
11 replies to this topic
#1 beardylondon
beardylondon
  • 1,503 posts
Posted 02 March 2019 - 01:21 PM
I wanted to convert my Mk1 from a Hydraulic brake light switch to an Electric brake light switch, as per the post 1976 cars. After finding out none of the parts are currently available to mount an electric brake light switch in car that never had one originally, my Dad kindly offered to make me a bracket. He thought rather than copy the original, which we only had one photo of, he decided to make something that would clamp on and be held by three 5mm grub screws. We used some scrap aluminium (hence the machined lines), which we bent to suit. Then tapped the 1/2" 20UNF thread for the switch and also tapped the threads for the grub screws and after some fiddling it all works as it should. We could of taken a bit more of the aluminium away and made it smaller, but it's not on show, so not an issue.
Using the grub screws obviously meant we didn't have to drill a new hole in an awkward position in the pedal box, or remove it. I used a genuine Lucas switch and the correct nut, both from eBay. For the wiring I used some 2 core cable for 12V, that already had a thin black PVC sleeve and ran the cable from the engine bay into the cabin.
Overall I'm very happy, as well has never having to worry about the old Hydraulic switch failing, the brake lights are much brighter. It's a win win as they say.
Edited by beardylondon, 25 July 2021 - 03:32 PM.
#2 unburntfuelinthemorning
  • 1,981 posts
Posted 02 March 2019 - 01:42 PM
Nice.  I like these sort of modifications.  I imagine the brake lights come on faster now too.
#3 beardylondon
beardylondon
  • 1,503 posts
Posted 02 March 2019 - 04:35 PM
Yes I think they do, I adjusted so theres no lag!
#4 MiniTim71
MiniTim71
  • 36 posts
Posted 26 July 2021 - 04:54 PM
Really great input and thanks to everyone for the responses.  Some good inspiration here, I think I will make my own bracket ...
#5 surfblue
surfblue
  • 1,827 posts
Posted 27 July 2021 - 10:14 AM
How are the lights brighter, surely they are either on or off?
#6 MiniCarJack
MiniCarJack
    Formally known as W1NG3D
  • Just Joined
  • 486 posts
  • Local Club: Midweek Minis
Posted 27 July 2021 - 10:19 AM
Probably the old hydraulic switch not giving a great electrical contact vs the new electric switch
#7 beardylondon
beardylondon
  • 1,503 posts
Posted 27 July 2021 - 10:49 AM
exactly
#8 Spider
  • 14,781 posts
Posted 27 July 2021 - 05:32 PM
Simple and neat solution, nice work !
#9 beardylondon
beardylondon
  • 1,503 posts
Posted 27 July 2021 - 10:35 PM
Thanks Spider
#10 Podman
Podman
  • 208 posts
  • Local Club: Snowdon Minis
Posted 22 January 2025 - 10:50 AM
This is brilliant. I've been through 3 or 4 hydraulic switches and I'm always a bit nervous, as to whether the lights are working or not.
Have you got any rough dims, please and I'll try and knock a similar bracket up in work.
Edited by Podman, 22 January 2025 - 10:51 AM.
#11 beardylondon
beardylondon
  • 1,503 posts
Posted 22 January 2025 - 12:10 PM
Thanks very much. I don’t have the dims unfortunately, and I’m not by the vehicle atm.
Edited by beardylondon, 22 January 2025 - 12:10 PM.
#12 bpirie1000
bpirie1000
  • Area Managers
  • 2,335 posts
  • Local Club: Amoc
Posted 22 January 2025 - 03:38 PM
A good resolution. I like your thought process..
