Sump Plug?
Posted 24 February 2019 - 05:54 PM
Posted 24 February 2019 - 06:13 PM
last owner did not want to pay to fix it
garage did not want to admit to messing up
last ower did not have the skill set to fix it
last owner was a cowboy and thought a bodge was a proper fix
they meant to fix it but never did as it held up or had no where to fix it
Beware of other fixes on the car
Posted 24 February 2019 - 06:31 PM
Maybe a small section of gearbox case thread came out with the plug bolt and Garage did what they did as a precautionary measure and loose as possible to avoid further damage hence the thread lock.
I'd just heat the washer red hot to anneal it, torque it as minimally as possible to stop leaks and see how long I could get away with it. It could last years like that.
Edited by jime17, 24 February 2019 - 06:38 PM.
Posted 24 February 2019 - 06:36 PM
Posted 24 February 2019 - 06:50 PM
Edited by JayKay, 24 February 2019 - 06:53 PM.
Posted 24 February 2019 - 06:55 PM
Posted 24 February 2019 - 07:01 PM
I've found over the years that the things I think look worth worrying about seldom are.... It's the ones I miss that end up the biggest problems.
Very true that. On a side note I can't get over how little rust there is in this car compared to my previous 2000 registered Classic Mini Cooper MPI!! I purchased that in 2011 and it was shameful how rusty it was!
Posted 24 February 2019 - 07:13 PM
Very true that. On a side note I can't get over how little rust there is in this car compared to my previous 2000 registered Classic Mini Cooper MPI!! I purchased that in 2011 and it was shameful how rusty it was!I've found over the years that the things I think look worth worrying about seldom are.... It's the ones I miss that end up the biggest problems.
No rust? Now you're just rubbing it in!
Posted 25 February 2019 - 08:25 AM
I wrap PTFE tape around the sump plug on my car. 6 months after a full restoration which included a rebuilt gearbox the sump plug started to give just as I was torquing it up. You know the feeling, when threads are just starting to let go? I didn't have the time or tool to fit a thread insert so I wrapped PTFE tape and have been applying it ever since.
Perhaps a copper washer was the best (cheapest?) way to seal a sump plug in the late 50's, but it's not the only way to keep oil in the engine.
