Flywheel Puller
15 replies to this topic
#1 Fastorq
Fastorq
  • 186 posts
Posted 22 February 2019 - 08:52 PM
Just bought a used 3 non elongated hole one off ebay.
It doesn’t fit the 998 flywheel I’m trying to get off.
Do classic mini flywheels have different PCD flywheel puller holes ?
#2 nicklouse
  • 19,067 posts
Posted 22 February 2019 - 08:54 PM
nope all the same. other than the difference between Verto and preverto. you most likely have the wrong one for the flywheel. note threads are fifferent. and the Auto has a 3rd PCD
Edited by nicklouse, 22 February 2019 - 09:00 PM.
#3 nicklouse
  • 19,067 posts
Posted 22 February 2019 - 08:59 PM
http://www.guess-wor...play.htm?id=501
#4 wile e coyote
wile e coyote
  • 1,230 posts
Posted 22 February 2019 - 09:53 PM
Or the laser one from halfords should do the job  - no disrespect to Guessworks's beastie which is apparently excellent and nigh on invincible, but for a singular job it'll sort you out.....just make sure after taking out the crank washer you put the relevant bolts in perfectly evenly or else your're asking for trouble...... crank up the pressure bolt tight, then some more, then some more, wait a bit, and then some more...... it'll come off - mind your feet!!
#5 Wiggy
Wiggy
  • 1,037 posts
Posted 22 February 2019 - 10:00 PM
The "taking out the crank washer" and "wait a bit" is important. Don't go monstering it up tight with a scaffold pole. You'll risk rubber ducking it. A 3' breaker should do it.
#6 Cooperman
  • 23,569 posts
Posted 22 February 2019 - 10:21 PM
Some come off very easily, whilst others are a real b****r.
It once took me almost a week to get an MPI flywheel off and I had to use my huge puller plus 'Arctic Freeze' and a big hammer. Eventually it released.
#7 Wiggy
Wiggy
  • 1,037 posts
Posted 22 February 2019 - 11:02 PM
Why is that, do you think? Poor tolerances from the factory? Assuming it's not because someone has been there before.
#8 Fastorq
Fastorq
  • 186 posts
Posted 22 February 2019 - 11:04 PM
Looks like I bought the wrong one .... sh£&.
Fortunately it only cost me £8.
Wonder if I can machine a flywheel centre ??
Edited by Fastorq, 22 February 2019 - 11:05 PM.
#9 nicklouse
  • 19,067 posts
Posted 22 February 2019 - 11:11 PM
if it is for a one off job rent it from Guess works but is you are going to do a few buy it.
having been through a few in earlier years
#10 Spider
  • 15,878 posts
Posted 23 February 2019 - 12:27 AM
From what I've noticed, it seems to be the Verto types that are the worst for this and looking at the aftermath, it appears they were either not fitted up tight enough in the first place and / or their design lends them to cause fretting on the tail of the crank.
#11 nicklouse
  • 19,067 posts
Posted 23 February 2019 - 12:32 AM
i have only ever removed one verto fly assy and that was with the Bstad and once the ball bearing had made its mark in the end of the drive bolt it came off quite easily
pre verto ones i have pulled many many of them most off high revving race engines and never had issues. my thoughts about the verto is that the mass is further away from the taper so anything being out has a greater effect?
#12 Fastorq
Fastorq
  • 186 posts
Posted 23 February 2019 - 01:06 AM
One I bought is top right in your box.
#13 nicklouse
  • 19,067 posts
Posted 23 February 2019 - 10:50 AM
That fits the pre verto version.
#14 grizzler73
grizzler73
  • 300 posts
Posted 23 February 2019 - 10:59 AM
The Minispares one is good, very sturdy. I bought one as I will have to rebuild a lot. It took a week to get the one off the 1098 I have!
#15 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 23 February 2019 - 06:17 PM
I found the application of heat and freeze spray played a big role in removing the flywheel off my clubby. That one was pretty much welded on and it was pre verto. Much cursing, big hammers and drifts, one knackered puller and it fell off after the application of heat and cold.
I think if i was done mini engines on a regular basis then Guessworks monster would be the ideal tool.
