I would rather pay a little more and get a remastered mini
Do you mean the David Brown Mini? They've done a cracking job of that.
Posted 23 February 2019 - 07:36 PM
Posted 23 February 2019 - 07:40 PM
Posted 23 February 2019 - 08:23 PM
Electric cars don't smell right. Nor have petrol engined cars since they had to have catalytic converters.
Posted 24 February 2019 - 10:14 PM
yes i would for the extra cost much more refined
Posted 25 February 2019 - 07:17 AM
Although legislation probably prevented it from happening it would have been brilliant if Rover had done this to the Mini - it's a proper up to date Mini without detracting from the character of the original.
Posted 11 June 2020 - 08:59 PM
They've opened up their order page now.
What do you guys think of the final specs and prices? I personally like that there's a choice of power inverters. I want long, easy drives, not fast bursts for racing.
specifications: https://swind.life/products/hpd-2/
price list / reservation page: https://webshop.swin...&product_id=261
Edited by ryanlogsdon, 11 June 2020 - 09:01 PM.
Posted 12 June 2020 - 01:21 PM
So just shy of £8000 for the motor and diff, plus £2400 for the low-voltage inverter...
It looks like the low-voltage version would give you roughly 70 hp at the wheels (70 kW peak from the inverter).
It's a nice package for a Mini or other small classic car, and I guess a few people will have pockets deep enough, but there are much cheaper ways of doing it. There are a few good conversion shops in the US that could probably put together a cheaper solution for mating to a small transaxle (transverse gearbox and diff).
Posted 12 June 2020 - 06:07 PM
Hey Malcolm,
If you've got some links, I'd love to check them out!
Thanks,
Ryan
Posted 12 June 2020 - 09:35 PM
Posted 13 June 2020 - 06:37 AM
Posted 17 June 2020 - 06:01 AM
Hi Ryan,
Here's a link to HPEVS, which makes it's own range of AC motors for use with Curtis inverters (which Swindon also uses in its low-voltage system):
https://www.hpevs.co...conversions.htm
There's a list of US conversion shops on the linked page. I've bought a few items from Thunderstruck Motors in the past and I know EV West have done many good conversions (including a Mini Moke), but I can't vouch personally for the others.
Thanks Malcolm!
Posted 17 June 2020 - 06:15 AM
So its 8 grand for the motor and then you have batteries on top?
To my understanding, it'll mount perfectly to a Mini's transmission. That means no adaptor plate, and as low-tech as a mounting plate is, I'm seeing that they're really expensive, some are over a thousand dollars, because they all have custom hole patterns.
But I'm with you, I was hoping for a lower price. A few months back, I tallied that this kit (or "crate motor" as they call it) will replace about $6000 worth of components. I think that extra $2000 is their convenience fee.
I'm going to call the makers and see what more I can learn. If I find anything of interest, I'll let you guys know.
Ryan
Posted 17 June 2020 - 06:36 AM
Posted 17 June 2020 - 08:52 AM
Ryan
The Swindon unit completely replaces the original Mini transmission with a single-gear reduction and differential in one housing. You need to use their custom output shafts to replace the original Mini shafts.
I guess you will also need to add new mounting points to the Mini subframe, as the existing engine mountings are unlikely to be in the right place.
