Hinge Pillar Holes
Posted 17 February 2019 - 04:11 PM
Posted 17 February 2019 - 04:16 PM
A quick one guys my mini door pillar hinge mount holes have been enlarged and arent round what size hole are the hinge bolt holes on the pillar and flitch panel please
These may have been enlarged to enable the door to be fitted decently. Quite common to find them like this. Mine are slotted to enable the door to be raised in the cutout.
Posted 17 February 2019 - 04:24 PM
The ones on this car are rotted and need attention i dont have anything here to take measurements from when making a new section these are oval and at least 12 mm atm but being ime making a new section i will make at standard size and oval later should i need to i will trial fit the doors (get them tmorrow) before any cutting and welding is done
Posted 17 February 2019 - 05:04 PM
Post up a picture if you can.
Posted 17 February 2019 - 05:40 PM
Edited by stumpy75, 17 February 2019 - 05:44 PM.
Posted 17 February 2019 - 06:36 PM
This is what it looks like when you disassemble the A post
This is thicker and is integral to providing the strength that you need.
And this is the part on the Minispares website
https://www.minispar...|Back to search
Posted 17 February 2019 - 06:44 PM
Posted 17 February 2019 - 06:49 PM
If you look at the picture i posted of my A pillar stiffener you can see there are not that many spot welds holding it all together. 16 all in all BUT thats just the post, there are some obviously where the fitch attaches as well.
Posted 17 February 2019 - 08:03 PM
Posted 17 February 2019 - 08:05 PM
I see that yes which 1 of your builds did that come off mate please
Project Paddy.
Posted 17 February 2019 - 09:03 PM
Posted 17 February 2019 - 09:41 PM
Just had a good read of it matewandwgreat work fairplay and the work you did on that pillar was top notch fair play
I repair large Civil Aircraft for a living so this is second nature and thanks for the comments.
Posted 18 February 2019 - 12:41 AM
So if the rot is confined to just the flat section the hinge sits on and the rest is clean from grot could a new flat be welded either in situ or by drilling out the spot welds removing the stiffener repairing and then then sblending the welds ect andrefitting back into position ?
Edited by stumpy75, 18 February 2019 - 12:43 AM.
Posted 18 February 2019 - 02:09 PM
Ah that explains a few things
Yes in theory but I would say this, there is always something lurking that is unseen so personally I would seriously consider popping he whole thing out. That way you won’t be wasting your time later on.
Posted 18 February 2019 - 04:58 PM
