1293 Pistons And Cr
32 replies to this topic
#31 Spider
  • 14,821 posts
Posted 10 March 2019 - 05:03 PM
Ok so I have posted this info on my other thread 1275 Rebore.
Using the DTI Gauge I found TDC and then set the gauge on the block face and zero'd it. Then gently releasing the magnet I span it around over the piston crown and re-engaged the magnet. Doing this a few times and on 3 of the 4 pistons I found the piston to deck height to be 15 - 15.5 thou.
This in not an accurate method to measure TDC.
If you are going to use a dial gauge, then mount it so the plunger is over the gudgeon pin, not off to the side of it like this ^. With the normal piston to bore clearance and the rock you'll have on a cold piston, that could be anything up to 0.010" off.
Also, if using a dial gauge, always measure with the piston rising, not falling.
A more accurate method again is to use a Piston Stop.
#32 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 10 March 2019 - 05:42 PM
So when checking TDC always do it on the rise (I believe I did) but I'll make sure I measure at the centre of the piston.
The picture above though was measuring the piston crown to deck height.
#33 Spider
  • 14,821 posts
Posted 10 March 2019 - 05:59 PM
OK, but the same applies and for the same reason.
At a pre-machined stage, Cooperman's method would be a good guide to this, but I'd suggest running an Oil Stone over the deck for about 10 minutes first,
