Injection Port Tube. What Are These?
engine
8 replies to this topic
#1 psyb0rg
psyb0rg
  • 43 posts
Posted 01 February 2019 - 05:10 AM
I just got a valve job done on my Canadian Mini 1000's head. The machine shop removed these brass tubes from where the smog/air pump air rail connects to the head. These seem to be a Canadian-only part. They are number 12 on the image here: http://www.somerford...age=page&id=116
This is where the air pump rail attaches:
The tubes fit in the holes in the head, and the rail connects over them. There were only three of these tubes. Does anyone know how these work, and do I absolutely need to source the 4th one? I wonder if these are used to cross the coolant passage.
#2 psyb0rg
psyb0rg
  • 43 posts
Posted 01 February 2019 - 06:49 AM
I just checked the head, and the brass tubes reside inside this tract, that connects the air pump to (I think) the valve chamber(?)
#3 MacGyver
MacGyver
  • 1,028 posts
Posted 01 February 2019 - 07:25 AM
They had them on Austin Maestros too in Switzerland, can't help with the tubes tho.
Are you planning to refit them?
#4 psyb0rg
psyb0rg
  • 43 posts
Posted 01 February 2019 - 07:43 AM
Yes, I'll be fitting the smog pump to clear emission tests.
#5 MacGyver
MacGyver
  • 1,028 posts
Posted 01 February 2019 - 10:40 AM
Can you get some made by a machine shop?
#6 Ethel
  • 26,822 posts
Posted 01 February 2019 - 12:28 PM
Hydraulic fittings supplier maybe? There are a few about making up lines for JCB's etc.
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 01 February 2019 - 04:39 PM
Interesting to know how the plain end seals in the combustion chamber.
What is the outside diameter of the tubes ?
#8 psyb0rg
psyb0rg
  • 43 posts
Posted 01 February 2019 - 06:55 PM
Outside diameter is 4.6mm. They're not too snug in the hole.
#9 psyb0rg
psyb0rg
  • 43 posts
Posted 01 February 2019 - 06:59 PM
I got these brake lines that are 0.1mm bigger (outer diameter) than the tubes. I think this should work.
Edited by psyb0rg, 01 February 2019 - 06:59 PM.
