I've currently got the engine out of my MPI stripped out on the bench to fix some oil leaks & a good clean & paint up.
Whilst its in bits should I fit a new camshaft & would I get any gain out of a performance camshaft without a performance head.
My budget won't currenlty stretch to a cam & head so I thought maybe fit a cam now & then a head later as a head can be fitted with the engine in the car.
Any views or advise would be great.
As a straight answer to your questions:-
"Should you fit a new camshaft"? ... You don't give the mileage and use, but not unless it is badly worn.
"Should you fit a performance camshaft"? ... NO ... because you have no way of telling your ECU that you have done it.
"Would you get any gain out of a performance camshaft without a performance head?" ... Yes ... but probably at the loss of some tractability because you have no way of telling your ECU that you have done it.
Having said that:- There are people who can 'map' an ECU to match a cam, SO, if you can do a deal with someone for a cam and map, buy and fit the cam, save for the map, save again to have your head flowed and polished and provided that you don't go for too much power, take comfort that BMC/ Leyland included quite a lot of reserve strength in the Mini "lump", to mitigate warranty claims.
It is a testimony to that reserve of strength, that the late Barrie Williams gave BMC their first international rally win in an unmodified showroom car (except for lights and sump guard), and Barrie didn't hang about on those Welsh special stages, either on the ground or in the air.
