K20 Race Frame Build
66 replies to this topic
#16 mmaci
mmaci
  • 35 posts
Posted 24 February 2019 - 05:27 PM
Afternoon everyone,
Not a particularly exciting update. It's more been a month of getting through wee jobs that need done. Carbon for the switch panel is being cut and will be sorted soon, I pulled the wiper motor and linkages and rear lights out of an old mini I've had for years, gave it all a clean and paint. Saves a few quid and satisfying to see!
33285039868_5d5be77be3_c.jpgUntitled by Mark Maciver, on Flickr
This will get mounted on a bracket just above where the cage meets the front subframe, about as close to its original position as possible.
47198535561_f1d22038dd_c.jpgUntitled by Mark Maciver, on Flickr
The rear bulkhead is ready for drilling and nutserting to the cage. I'll aim to make this as sealed as possible but once the side panels are in the rest can wait till after it's running.
40233805853_bd62603b52_c.jpgUntitled by Mark Maciver, on Flickr
Nice shiny arrival;
47198473051_84f14e6d22_c.jpgUntitled by Mark Maciver, on Flickr
This'll need a bracket made, as will the header tank. Any suggestions on where to fix it welcome. At the moment my plan is a bracket to mount them both behind the passenger seat (engine side of bulkhead) on a bracket coming down from the harness loop bar.
Most pressing job next is sorting what seems to be a common issue.
40195364253_dc2fdb54cc_c.jpgUntitled by Mark Maciver, on Flickr
The bottom UJ catches the brake pedal. Not ideal but I think the best way is to do as cptkirk has and cut where the bolt is and weld it.
Hopefully this week I'll get my box from gonzo which hopefully solves the rear brake issue and allow me to select gears! We seem to be missing a bag of banjos and fittings for the brakes which has led to a fair bit of head scratching. Hopefully enough will be done for the car to go off to PerformanceTek in March so a busy few weeks ahead.
Cheers,
Mark
#17 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 25 February 2019 - 12:36 PM
If you do weld try n get something clamped to the UJ to dissapate some of the heat.
I was looking through my old photos for wiper motor bracket and was going to post them in here for you, but after seeing you noticed the welding of the UJ you've probably seen my effort...Let me know if not and I'll DM you
Looking good..
#18 mmaci
mmaci
  • 35 posts
Posted 25 February 2019 - 07:41 PM
Thanks, I have indeed seen the pics, a great help as always!
#19 mmaci
mmaci
  • 35 posts
Posted 01 March 2019 - 08:26 PM
Few wee jobs sorted this week. Collected my carbon fibre and steering column from an excellent engineering company which is handily round the corner from the house. They used a water jet to cut the carbon and their welder sorted the column without damaging the UJ:
46330758625_cae6656981_c.jpgUntitled by Mark Maciver, on Flickr
47193291922_00c73fda83_c.jpgUntitled by Mark Maciver, on Flickr
33369573128_8331a25828_c.jpgUntitled by Mark Maciver, on Flickr
32303237957_4d502e5726_c.jpgUntitled by Mark Maciver, on Flickr
The red part on the UJ will need ground further but it's much improved on before. Also sorted the bracket for the wiper motor and fuel pressure regulator. They both just need drilled and painted before fitting.
47245378331_ffc5987917_c.jpgUntitled by Mark Maciver, on Flickr
32303237897_f527fd2c4c_c.jpgUntitled by Mark Maciver, on Flickr
All small jobs in the grand scheme but nice to get them out of the way.
Have a good weekend  :D
#20 mmaci
mmaci
  • 35 posts
Posted 21 March 2019 - 12:17 PM
A nice chunky update, starting where I left off..
Wiper motor and screen wash pump are in. Using a very simple in-line pump which means I'll be able to fit a wee bottle wherever I can.
32491910767_66748665b6_c.jpgUntitled by Mark Maciver, on Flickr
We have gears; Gonzo's bracket saved the day, all in place now and after some fiddling to find the best place for the forward-most cable brackets I'm happy to admit the gears feel far tighter and nicer than I was expecting! We had to add a dog leg to the gearbox end as the tab added by the previous owner/Zcars didn't line up with the cables at all.
40327965873_2ca9b7c5fe_c.jpgUntitled by Mark Maciver, on Flickr
33557704408_01507bb314_c.jpgUntitled by Mark Maciver, on Flickr
Getting these cables into place then set off a chain reaction of jobs. As we don't have the raised tunnel inside the car, the cables take up where the coolant pipes would normally sit up in the recess of the tunnel. Once we knew how low they'd have to be to avoid the gear selector we could come up with a way of holding them there. Nothing fancy but some flat bar is fine for now. In position they sit around the same height off the ground as the sump is.
47380951732_8e5961e343_c.jpgUntitled by Mark Maciver, on Flickr
At the radiator end neither of us were happy with how the pipes were sitting. We've added a few studs to the fuel tank which allow us to use P clips to hold the pipes now. Much better fitment now.
33557704158_7217be17fa_c.jpgUntitled by Mark Maciver, on Flickr
40467944723_984579d932_c.jpgUntitled by Mark Maciver, on Flickr
The fuel pump has also been fixed in the tunnel, it's the neatest place having looked at a few options. It's fed through an inline filter and the hoses will be clipped up into the tunnel in due course. Also fitted the Revotec fan using the existing holes in the radiator and one of their universal mounting brackets. In all honesty I know of a few K-swaps who have fitted fans but rarely if ever need them but better safe than sorry.
In the engine bay the FPR has been fitted (thank you cptkirk for the idea) but yet to be plumbed. The header tank has been mounted, also by nutsert to the cage and plumbed. Pressure testing the system beforehand gave good results but there is the tiniest of drips coming from the black blanked of heater pipe. The throttle cable was a 5m kit bought from eBay which has worked a treat. It's run through the tunnel with everything else, mounted onto the existing bracket at the throttle body and held by the fixings which came in the kit for going through the front bulkhead.
46710748664_d50e43a42b_c.jpgUntitled by Mark Maciver, on Flickr
The front subframe is now mounted to the floor, the spacers are made of plastic. More than strong enough and we happened to have the plastic already.
47380951422_0b35c5588b_c.jpgUntitled by Mark Maciver, on Flickr
Battery is secured behind the passenger seat. Went with the Odyssey PC680, seems to be well reviewed and its absolutely tiny. I do plan on adding a quick charge point so its easy to put on trickle charge.
40467943723_074b1e3950_c.jpgUntitled by Mark Maciver, on Flickr
The rear brakes have been a bit of a nightmare. Gonzo supplied me with the Citroen type rear set up - absolutely perfect service and parts but I had an issue with wheel fitment (again). So as the car needs to be mobile for now we've fitted the Wilwood 4-pot kit without a handbrake that came with the car. We have a hydraulic handbrake setup that can go in later, just not ideal/legal for road use. That issue can be solved later by sorting new wheels. Also fitted the exhaust and heat shields for the gear cables.
46518611995_cc46c7d482_c.jpgUntitled by Mark Maciver, on Flickr
47380950722_fb7a727e2d_c.jpgUntitled by Mark Maciver, on Flickr
So for now she's back on the ground and tomorrow we'll delivering her to PerformanceTek in Glasgow...
32491911417_76904f81fd_c.jpgUntitled by Mark Maciver, on Flickr
46518612105_6145f8aa41_c.jpgUntitled by Mark Maciver, on Flickr
#21 KTS
KTS
  • 2,420 posts
Posted 21 March 2019 - 06:06 PM
..that's starting to look quite exciting now !
#22 minibugga
minibugga
  • 87 posts
Posted 01 April 2019 - 01:52 AM
Looking good Mark, nice progress.
As for the rear calipers you might need to take off some material from the external part of the caliper. Maybe someone has a picture around, otherwise I will make one for you this week.
Best wishes, Gonzo
#23 mmaci
mmaci
  • 35 posts
Posted 04 April 2019 - 10:07 AM
Best wishes, Gonzo
If you can that would be great for future reference. Thank you!
#24 mmaci
mmaci
  • 35 posts
Posted 09 September 2019 - 05:25 PM
A wee update..
So in April (what feels like quite some time ago!) we delivered the Mini to Gerry at PerformanceTek. Although we don't have the car back quite yet we have had some excellent updates. We deliberately didn't want to put a deadline on this because it's been a busy summer without having the Mini to work and it's given us a chance to freshen up the garage too.
Before leaving..
48699949892_41bd5d6b03_c.jpgUntitled by Mark Maciver, on Flickr
Some precarious loading..
48699779356_32aaf476a2_c.jpgUntitled by Mark Maciver, on Flickr
Gerry's cracking race trailer made unloading a lot easier.
48699949502_d233fc9d09_c.jpgUntitled by Mark Maciver, on Flickr
And the garage has had a well needed spruce..
48699440898_800b550909_c.jpgUntitled by Mark Maciver, on Flickr
Now on to the wiring. RacingCircuits have done an incredible job of the loom. Although it's only pictures I've seen so far the workmanship and overall look of it is superb.
48699776496_3d4d6d18a4_z.jpgUntitled by Mark Maciver, on Flickr
48699947392_99b4128ee6_z.jpgUntitled by Mark Maciver, on Flickr
48699437553_3c7f8eaa43_z.jpgUntitled by Mark Maciver, on Flickr
48699947032_51ef0c16ef_z.jpgUntitled by Mark Maciver, on Flickr
48699437688_e13c6e3cf8_z.jpgUntitled by Mark Maciver, on Flickr
And on her way back to PerformanceTek for the ECU fitting, FPR plumbing and mapping.
Thanks for reading folks,
Cheers.
#25 KTS
KTS
  • 2,420 posts
Posted 09 September 2019 - 07:08 PM
..bet you had the van in gear, the handbrake on, and the wheels chocked when you loaded that one
if the quality of work continues at this level the finished product is going to be spectacular !
matching garage floor is a nice touch too  ;D
#26 mmaci
mmaci
  • 35 posts
Posted 09 September 2019 - 08:32 PM
You better believe that van wasn’t going anywhere!!
Thanks mate, I don’t think either of us realised how OCD we could be with things till this started but it’s paying off.
#27 mmaci
mmaci
  • 35 posts
Posted 15 November 2019 - 01:02 PM
And we have life...
Big day yesterday as she's finally running. Some initial teething problems where there was fuel, compression and spark but just no life. Turned out the injectors were signalling that they were opening but not actually opening. Thankfully Gerry at PerformanceTek had a spare set and stuck them in. This was a big relief for us because we ultimately know nothing about the engine's history prior to us getting it. It's been serviced, clearances checked etc but sometimes you just never know. All good in the end;
49068366388_24277a4446_z.jpgUntitled by Mark Maciver, on Flickr
Now happy idling at 900RPM. This is from the Hondata app which we'll be using as a dash for now. Bluetooth connection to the ECU and a Kindle Fire mounted infront of the driver. Hopefully not permanent but good enough until everything else is done. Hasn't been on to his Dyno yet but hopefully that's coming soon. A bit of an unknown over what power we'll have as its a K20Z4, which normally has drive by wire throttle body, using a K20A2 cable throttle body.
49068366263_026359efff_z.jpgUntitled by Mark Maciver, on Flickr
On a less exciting front I've been robbing our very sorry looking donor for more. We've had this L reg mini since I was 16 and although the shell is absolutely buggered now, it's proved very useful for simple stuff like wipers motor, linkages and handbrake bracket I've just removed. That'll go behind the one already in the Vtec to support the rear of the hydraulic handbrake.
49068888411_5fb33cfbf1_z.jpgUntitled by Mark Maciver, on Flickr
49068367163_c78e3f5b5d_z.jpgUntitled by Mark Maciver, on Flickr
49068366763_0decac13d2_z.jpgUntitled by Mark Maciver, on Flickr
It's eventual home:
49069094212_c9e1d5f79a_z.jpgUntitled by Mark Maciver, on Flickr
I've ordered Miglia arches from Carbon Weezel which I'm really looking forward to seeing but less so fitting them!
Thanks for looking. Hopefully the next update she'll be home in the garage ready for (hopefully) finishing in time for summer!
#28 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 17 November 2019 - 04:31 AM
Awesome build mmaci, Ben and Nick from the Carbon Weezel do superb work, I don't think you'll be disappointed.
#29 mmaci
mmaci
  • 35 posts
Posted 27 November 2019 - 04:52 PM
I'm sure some of you have seen on Facebook already but that's the tuning sorted. Delighted with the results but you can listen for yourselves..
49106306057_02c0921cbd_z.jpgUntitled by Mark Maciver, on Flickr
49106122071_40aa35b046_z.jpgUntitled by Mark Maciver, on Flickr
49105611373_7219bcc533_z.jpgUntitled by Mark Maciver, on Flickr
-233 BHP
-202 at the wheels
-170 lbft Torque
Collecting her end of next week and then home for the rest of the build  :D
#30 KTS
KTS
  • 2,420 posts
Posted 27 November 2019 - 05:00 PM
awesome.  no wonder you're smiling !!
