Can anyone tell me please, where are the body earth connections on the main harness for a 93 (Mk5?) car? I'm getting some really wierd electrical issues and starting to wonder if the body earths are all good. I've looked around the engine bay and can't see any there, and all the documentation I've checked does give that information.
Best Answer cal844 , 25 January 2019 - 10:42 AM
A 1993 car will have the earth's on the right hand inner wing triangle (as viewed from driving seat on RHD car)
Give them all a rub back to clean metal and then rub the paint on the shell back to shiny metal, then refit the earth's and try then.
What are the electrical issues you are having?
Go to the full post
Posted 25 January 2019 - 09:02 AM
Posted 25 January 2019 - 09:42 AM
what issues ?
there is the engine earth strap.
there is an earth in the boot for the rear lights.
there will also be a few other earthing points.
Posted 25 January 2019 - 09:59 AM
Is the Mk5 one with the plug & socket earthing arrangement on the left hand (passenger) inner wing triangle?
Has 6 male spade connectors in a plastic housing that bolts to a captive nut and then a corresponding plug with many earths going to it is part of the loom
Posted 25 January 2019 - 10:42 AM Best Answer
Posted 25 January 2019 - 03:42 PM
Thanks for the responses and pointers guys. As for issues, there are enough to be doing my head in
Examples are, sidelights going out with headlights on, hazards but no indicators (checked relay contacts, might try replacing) HRW works one time, then not the next, brake test switch bulb on with low level, not on test, dip beams but no mains (wondering about column switch?) wipers v. slow and no self park, and so it goes on......
Posted 25 January 2019 - 05:16 PM
The indicators could be the relays, there are two
Posted 26 January 2019 - 09:02 AM
Indicators sorted. Had a spare 5-pin relay. Used to test and hey presto, all working as they should. New relay will now be purchased, to keep my spare as a spare. Next task, will be to bottom out the headlight issues.
Posted 26 January 2019 - 10:22 AM
Posted 26 January 2019 - 11:03 PM
Clean all the favourite ones in the bundle behind the grill, follow the wires and see that they are not broken or chafed, I think there are a couple of small earths either side too.
Headlight earth's go into one wire and go to the driver side bulkhead triangulation.
The the two rear light cluster earths
Also check behind the Speedo binnacle for 4 inline fuses, my 1993 car and my dad's IJ loom both had them
Posted 28 January 2019 - 08:55 AM
Thanks for the inputs again guys. Eventually found that all the fuses bar sidelights had blown, one to the point that it had "welded" itself inside the fuse holder. One of the headlamps had a broken dip element and the other was completely white inside the envelope!. Changed bulbs and refitted correct fuses and all is now working as expected. Not sure if it was something I did, or were they like that from before or during the body repairs.
Posted 28 January 2019 - 10:38 AM
Posted 28 January 2019 - 10:41 AM
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
