Fuel Pump For 45 Weber
Posted 05 January 2019 - 05:30 PM
Posted 05 January 2019 - 05:36 PM
Posted 06 January 2019 - 10:49 PM
Posted 06 January 2019 - 10:55 PM
Will an mpi in tank pump run a 45 weber for a 1380 rally prep engine?
way way too much pressure. so Not really but you could with a suitable regulator and return fuel set up but i would not want so much high pressure fuel about.
Posted 08 January 2019 - 07:23 AM
Edited by James Harris, 08 January 2019 - 07:24 AM.
Posted 08 January 2019 - 07:26 AM
Posted 08 January 2019 - 05:54 PM
All you will need is a normal Facet 'square' pump. That will supply all the petrol your engine will need.
Posted 08 January 2019 - 06:44 PM
I use the good old Mitsuba pump with the 45DCOE. Facet red top should be okay also as the German Hardi-pump which regulates itself as the Mitsuba does.
https://www.hardi-au...ts/pumps-1224v/
