Rocker Cover
24 replies to this topic
#16 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 30 December 2018 - 09:50 AM
I have several of them, some have the outlet going left and some right. I'm not sure why though? Do you know Moke Spider?
#17 Chris.Williams
Chris.Williams
  • 679 posts
Posted 30 December 2018 - 05:11 PM
Hi scoop,
I don’t know moke personally, but I’ve had a few good yarns on here with him and have bought parts from him before.
Really nice and knowledgeable guy.
Are you wanting to sell a cover?
#18 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 31 December 2018 - 11:13 AM
Hi scoop,
I didn't mean if you knew Moke Spider, I was asking Moke if he knew why some went left and some went right!!! I have observed a lot of his knowledge on here and wanted to pick his brain about that.
Yes I would be willing to sell a cover, I would need to work out shipping to you though.
#19 Spider
  • 15,880 posts
Posted 31 December 2018 - 05:33 PM
Happy New Year everyone !!
Scoop, now you mention it, there are Right and Left pointing types.
Off hand, I'm not sure why, not a Rocker Cover I use much at all so never looked much in to their precise origins.
I seem to recall they were only fitted to the small bore engines.
If I recall, the early ones, as fitted to the Mini and Morris 1100 were used with a 1-1/4" SU and had an adaptor between the Air Filter Elbow and the Carb that they plumbed in to. I ** think ** they pointed off to the LH Side of the Car (Water Pump end of the Engine).
Later, as they went to a CCV System, the Adaptor was dropped and it was plumbed in to the CCV Port on the Carb Body (I think !).
#20 Chris.Williams
Chris.Williams
  • 679 posts
Posted 31 December 2018 - 06:52 PM
Hi scoop,
Haha right!
Ok I’m glad we cleared that up.
I’ll send you a PM with some details for a delivery address.
#21 mikal
mikal
  • 240 posts
Posted 01 January 2019 - 02:59 AM
My Mini K's (Oz model, 1098cc, 1969,'70 and '71) had them..
#22 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 01 January 2019 - 08:46 PM
That would make sense.
I should one day take a photo of all the different covers we had, I probably have 6 or 8 different ones!!!
#23 Spider
  • 15,880 posts
Posted 01 January 2019 - 10:55 PM
There were indeed a few covers.
To make a bit of a start on your excellent suggestion Scoop, I've come up with the following, but need to confirm some of this;-
I could only find references to 4 different unique Aust Rocker Covers, but I feel there may well have been more, Scoop, as you've mentioned you've got 6 or 8 different ones;-
The earliest was fitted to the 850. This appears to be a plain cover with no breather at all, P/N AYA185 These were also fitted to the 998 engines for a while
The Oil Separator, fitted to the Cover and pointing off to the LH (Radiator) side was available as a separate item, P/N AYA112 and could be fitted to the AYA185 Rocker Cover.
As a complete item, the AYA185 Cover, together with the AYA112 Separator was under P/N AYA184.
The Later Rocker Cover, with the Separator that faces off to the RH (Flywheel) end has P/N AYA253.
I stress, don't take this as gospel.
Here's an AYA184 and a AYA253 Cover (sorry for their appearance!)
This is the adaptor that was fitted to the 1-1/4" HS2 Carb, between it and the Air filter Gooseneck
P/N AYG120
I also found this snippet of info;-
Be great Scoop if you wanted to add some photos of yours
#24 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 02 January 2019 - 08:46 AM
See how this goes, first time photo post...
20190102_182400_zpsjldddmhr.jpg[/URL]
#25 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 02 January 2019 - 08:47 AM
I have another one somewhere, it has the stud cutouts for my GT.
