Fia Kill Switch Fitted. New Relay Module. Engine Won’T Switch Off
11 replies to this topic
#1 Bonniedog
Bonniedog
    Just On Tickover
  • 5 posts
Posted 28 December 2018 - 11:12 PM
Hi,
I’m stuck with a problem with my mini and am hoping someone can point me in the right direction please.
I have a 1991 1275 spi, I’ve used it in the Mighty Mini race series a few years ago and am hoping to get back out in it next year at some point.
The problem started following a recent engine rebuild. On putting everything back together the engine suddenly refused to rev past 3,500 rpm. I changed numerous things and the only thing that made any difference was replacing the relay module (part number YWB10022). The engine seemed to go back to normal, was running well and revved away quite happily but then refused to switch off! Switching the ignition off made no difference neither did the battery cut off switch!
Got a smell of warm plastic and a little bit of smoke coming from the box with the cut off switch in it. Ended up disconnecting the fuel pump to stop the car.
I have very limited knowledge/experience with car electrics. Never had this problem before, the kill switch and ignition switch have both worked perfectly in the past. As far as I can see everything is connected as it should be, all fuses etc look ok. For the sake of a couple of quid I replaced the resistor, just on the off chance, but it made no difference at all, there was no smoke the second time around but the resistor felt very hot by the time I’d got the fuel pump unplugged and stopped the engine.
Any help/pointers would be gratefully received.
Really hoping for a relatively easy fix/list of things to check before I have to remortgage the house and call an auto electrician!
#2 Sussex_pete
Sussex_pete
  • 73 posts
Posted 29 December 2018 - 08:26 AM
Immediate thought is that you have got an alternator supply to the wrong side of the cut-off switch. Thinking of the wire that normally runs from the alternator to the solenoid. I maybe wide of the mark, but seen it before like this on other cars
#3 Bonniedog
Bonniedog
    Just On Tickover
  • 5 posts
Posted 13 January 2019 - 05:12 AM
But the switch worked perfectly before the relay module started playing up. I’ve not touched the wiring for it other than replacing the resistor
#4 kit352
kit352
  • 244 posts
Posted 13 January 2019 - 07:49 AM
Sounds like the relay fused and didnt switch. Too much power maybe? Can you check the relay with a meter to see if its switching and how much voltage its getting? Do you have the relay hooked up properly- low voltage on the relay side and high voltage on the switched side? Its really easy to mess them up.
#5 mikal
mikal
  • 240 posts
Posted 14 January 2019 - 04:03 AM
Stop the engine by stalling it..
#6 Bonniedog
Bonniedog
    Just On Tickover
  • 5 posts
Posted 27 February 2019 - 01:33 PM
Not sure the scrutineers will be happy with that as a plan!!
#7 Bonniedog
Bonniedog
    Just On Tickover
  • 5 posts
Posted 27 February 2019 - 01:37 PM
The old relay pack is knackered and has been replaced. Having looked inside it the fuel pump relay is black and looks to have cooked itself. The new relay pack works fine in terms of the engine revving as it should but with the new relay pack fitted the engine won’t shut off either with the original ignition switch or the cut off switch.
#8 dotmatrix
dotmatrix
  • 439 posts
Posted 27 February 2019 - 02:15 PM
are you sure your kill switch is wired up correctly? my switch disconnects the battery and disconnects the power to the ignition coil.
#9 Bonniedog
Bonniedog
    Just On Tickover
  • 5 posts
Posted 27 February 2019 - 05:44 PM
Yes, as above everything worked perfectly for two years before the relay pack died. Ever since I replaced that this new problem has started
#10 nicklouse
  • 18,583 posts
Posted 27 February 2019 - 10:18 PM
i would be checking the wiring again. or getting another set of eyes on it.
#11 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 27 February 2019 - 10:31 PM
I'd second this, it's so easy to wire replacement parts wrong, been there, done that... Thankfully I'd noticed the mistake in time, so no damage caused.
#12 GraemeC
GraemeC
  • 7,438 posts
Posted 27 February 2019 - 10:36 PM
I’d test out the isolator switch with a meter - whatever fried the relay could easily have welded some contacts together in the switch.
Unfortunately some of those kill switches aren’t as reliable as you’d expect for a safety item, although they usually go weak and fail open.
Edited by GraemeC, 27 February 2019 - 10:37 PM.
